Varnish and Epoxy~ a Professional Wood Finish for Teak Part1
Varnish and Epoxy~ Part2
Varnish over epoxy by West System.
When varnish is used alone as a coating, it is constantly fighting two distinct battles. One is to stay attached to a substrate that is expanding and shrinking as the moisture content of the wood changes. Seasonal changes in moisture content occur because varnish is not a particularly effective moisture barrier. When the wood changes dimensions, it forces the varnish to stretch and shrink in order to stay attached. Given enough stretch/shrink cycles, the coating will eventually crack.
The other battle is oxidation from exposure to the sun's UV light, a phenomenon that contributes to loss of gloss and cracking.
Three coats of epoxy followed by three coats of varnish can achieve the same depth and look of twelve or more coats of varnish. Because there are no solvents evaporating away from the epoxy, it builds thickness faster per layer than varnish and it doesn't shrink when it cures. In addition, three or more coats of 105/207 can be applied per day.
More importantly, sealing wood with an epoxy moisture barrier dramatically lessens its stretching and shrinking. Varnish benefits from being applied over a stable substrate. High-quality marine varnish is formulated with UV filters. So, the epoxy coating benefits by getting the protection from UV radiation that it needs. WEST SYSTEM 105 Resin/207 Special Clear Hardener and varnish complement each other synergistically. The two in combination last longer than each coating by itself.
Varnish over epoxy A look at the benefits of undercoating with epoxy is a downloadable pdf. of the full article.
