You are a very inventive soal Nice pictures, great ideas, and it is fun to see new ideas at work
Look forward to your next move!!
Ron Dickey
...... Inside almost done--Trolly top has opening windows & roof.doors need assembling--pictured above waley windows..galley 1/3 done Cross Bow in Build Journals....http://www.tnttt.com/viewtopic.php?f=50&t=54108
The Temperature Sensor into the return air duct...
I was planing on using this 4 wire plug from the controls to an outside box for the AC disconnect..Seems to be the same wire ..What do you guys think...
Really nice build so far. Love the AC duct. I was going to do the same on my next one, but I got so many other thing that will be over engineered I will just stick my unit in a hole in the back wall.
Ok I gotta ask. Is your back wall of your shop made out of hay?
Yep.... The 30x60 pole barn is lined on the inside with 300 straw bales then covered with a clay-dirt-straw mixture (adobe)....R50 insulation is the result....
Finally got the galley figured out...We have one of those big refrig. we have been taking camping with our pop-up for some years now so I'm using it... That is why the tall height on the back before I started the radius..... The refg. opening height is 34'' and the counter height is 36'' from the ground.....I plan on putting the stove on a flip up swing out table...The other swing out will be a sink....
