Hot water on demand
Re: Hot water on demand
Postby Techguy » Sun Sep 23, 2012 10:36 am
We camped with friends that had a Coleman water heater. It worked well. I think it is about $200 and runs off the disposable propane bottles. You can also get on demand tankless waters for about the same but they require mounting by hanging or some other method.
Techguy
Postby halfdome, Danny » Sun Sep 23, 2012 7:13 pm
We've had one for several years and like it very much.
We use the cheap Walmart plastic tubs for wash and rinse.
Now if we can remember to bring it along, we'd get more use out of it. :lol: Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Greg M » Mon Oct 22, 2012 12:59 am
Now's the time to pick up a Coleman on end of season close-out. I found mine a couple of years ago at 50% off in November. You can hook it to a bulk tank with the regular adaptor hose and save on the little bottles.
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Postby halfdome, Danny » Mon Oct 22, 2012 9:48 am
biziedizie wrote:Been thinking more about this and I'm thinking this can't be too hard to make.
I must start some research on this unless someone has made one?
Here's some food for thought. Dan Hazard made this for heating water at the IRG.
You can see the full sized images in Cliff Uyeda's IRG album.
:D Danny
Last edited by halfdome, Danny on Mon Oct 22, 2012 10:12 am, edited 1 time in total.
halfdome, Danny
*Happy Camper
Images: 252
Postby halfdome, Danny » Mon Oct 22, 2012 10:22 am
:D Danny
So how exactly does it work? It sure looks cool!
My suggestion would be to just pay the man for the Coleman Hot Water On Demand unit and save money elsewhere.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby droid_ca » Mon Oct 22, 2012 10:51 am
Those systems can be very good just have to make sure that it is installed correctly as fires have been known to happen.....
My parents have a hot tub that they made that uses one just tow it up to the cabin fill with snow and in an hour or two it is too hot
I have been debating them as well as they don't take up that much space but every new and cool idea I hear my trailer keeps getting smaller
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby LarryJ » Mon Oct 22, 2012 1:35 pm
Image http://www.zodi.com/
You can get these at WalMart for $100
LRJ
Have Fun!!!
LarryJ
Images: 81
Postby titanpat57 » Mon Oct 22, 2012 10:38 pm
Another fantastic and well proven HWH is the Eccotemp L-5....I actually bought mine for around $100
Great little unit, unlimited hot water.
titanpat57
Images: 139
Postby M C Toyer » Tue Oct 23, 2012 2:32 am
Most of what I've read on these portable systems is they are not intended or recommend for indoor use although can be with proper ventialtion, both intake and exhaust. You would still need precautions for the open flame and the heat of the housing.
I suppose you could temorairily mount or place them outdoors and run the heated water through the normal inlet (if you even have one - if not I guess through a window or door) but would likely experienece some heat loss and pressure drop with the Coleman and Zoni battery powered pumps.
Are there higher priced systems that overcome these problems?
M C Toyer
Images: 11
Postby universal_exports » Tue Oct 23, 2012 10:02 pm
I have an echotemp water heater, but I have yet to install it.
I am still a long way from that point. lots to do.
universal_exports
Postby M C Toyer » Tue Oct 23, 2012 11:09 pm
Are you thinking inside or outside installation or not even at that point yet?
I may just plan for a separate outside compartment with fully vented hatch/door similar to most mobile homes. It would be located behind the sink. The sink and the shower will share a common utility wall cavity so the plumbing from the heater would enter there.
Not I have to decide on a water pump for the fresh water or a pressurized tank.
M C
M C Toyer
Images: 11
Postby universal_exports » Wed Oct 24, 2012 8:50 pm
I am mounting it behind the toilet, inside, vent the tube out the side if the camper near the top.
universal_exports
Postby navigator » Fri Sep 13, 2013 6:34 pm
We have an instantaneous heater, and wouldn't be without it! It makes you human!! The small units do not get very hot, so can be hung just about anywhere with no worry of starting a fire. The only part that gets hot to the touch (momentarily) is the top vent. Our trailer has brackets built into it that work perfectly to hang the heater. It connects to a 5-gallon propane tank, with RV water hoses to connect from an outlet on the trailer to the heater, then from the heater to a hand-held shower head with an on/off valve. There is a 30-gallon tank in the trailer, and a 2.5 gal/minute on-demand pump (and of course a battery). You can get two comfortable showers out of 5 gallons (meaning not just a quick rinse, but one you can actually enjoy). We normally set up a TexSport shower tent, it's 4' square so plenty of elbow room. The water gets quite hot! Also good for heating dishwashing water.
Note that there is just one hose to the shower; you adjust the temp using controls on the unit that limit flame size and water flow rate. You could build one of these into a compartment in the side of a trailer, and just open the cover door when it's in use. But it's very little trouble to do it the way I do.
112294
navigator
Images: 139
Postby georgiadawg » Sat Dec 21, 2013 7:55 pm
I'm thinking a coleman backpack stove/range on a coleman propane can, firing up into a wort chiller sold for home brewing and/or moonshining, with a water reservoir higher than the shower output/faucet, so it's gravity fed.
georgiadawg
Postby Globetrottermike » Sun Mar 02, 2014 7:34 pm
hi guys
i used this waterheater on my hotdog cart and it works well
never had any problems and i will have the same im my Trailer :)
http://www.amazon.com/dp/B009NWAW40
see u Mike
Logic will get you from A to B. Imagination will take you everywhere.
Globetrottermike
Images: 46
