by ssample » Sun Dec 29, 2013 7:19 pm
Thanks for the quick reply. I am studying the calculations in the Excel spreadsheet within the limitations of my dimensions and have some questions?
How did you arrive at the 60% ideal gas spring length percentage? This is about the size of extended gas spring that I can get into my TT above the galley counter.
Also, how did you determine that the ideal hatch attachment point should be 85% of the gas spring stroke length?
Finally, I did not understand that the attachment point inside the galley should be placed along a radius measurement from the (hatch) hinge center point equal to the extended length of the gas spring. This might work on the configuration in the hatch and galley layout that you show in the diagram that you provided in the post; but in my TT, the gas spring will be installed nearer to vertical and the extended gas spring hatch attachment location will be about 8 inches above the hatch hinge point with the hatch fully open. For now I have attached a photo crop that shows my configuration to help explain my situation and to assist you.
Thanks for your assistance. Steve
- Attachments
- TT Hatch Layout.jpg (111.43 KiB) Viewed 4180 times
