Junkboy999 wrote:The first thing I would try is the Generator. Even if it is not getting enough fuel up the fuel /air tube turning the cleaning level as slowly as you turned it around should've turned the lantern off. If it is working properly having the lever up should block all fuel coming out. They are $9 collars at coleman here in wichita. it is easier to try that first. if you're careful you can do it without breaking the mantles.
Here is Dave to show you how it is done. https://www.youtube.com/watch?v=Dhb8TMh4_g8
Zollinger wrote:Yup, I think you found yer problem. If careful you might try to straighten it out. Just be careful because it can break or pull out and then it's really junk. Don't ask how I know.
Junkboy999 wrote:Yep that looks bad.
PM me if you cant find a replace localy and I'll dorp a couple in the slow mail for you.
I just accired this box two day ago + other coleman parts for fixing a few lantern for a guy in your wood workers guild here in Wichita. They look a bit dingy but that is just the age of them.
