KCStudly wrote:Kerosene makes an excellent cutting lube for aluminum.
KCStudly wrote:Maybe radius the corners at the bottom of the buck slightly.
KCStudly wrote: ... Quick search found this instructable.
pchast wrote:I've been wondering about using epoxy and glass on a form.
pchast wrote:Would it adhere well enough in the molding to the Aluminum gutters?
KCStudly wrote:That's another good option, and you could make a plug for the top gutter, and a symmetrical one for both sides, then bond the three pieces together.
KCStudly wrote:Or just make it all out of wood and coat the ba-jesus out of it.
RandyG wrote:I'll make a model and send a few pics later tonight.
GuyllFyre wrote:The corners you're trying to make remind me a lot of wiremold aka wire raceway corners.
KCStudly wrote:Shown with the side gutters separated a bit for perspective. Could also be molded as one big piece. Note the squared outer corners, and the tapering from the middle getting wider toward the outsides across the top.
RandyG wrote:My idea isn't going to work for ya, after I tried it, I realized you want to have the radias on the inside lip of the gutter. My idea put the curve on the outside.
Heifer Boy wrote:Check out Jeff's molds for his Trail Top design http://www.expeditionportal.com/forum/t ... ost1502388
Users browsing this forum: No registered users and 28 guests
