vtx1029 wrote:
mikeschn wrote:vtx,
I can't make out your cnc table. Just wondered what you were using for the x axis? chain? rack and pinion? ball screws?
How about your Y and Z axis?
capnTelescope wrote:Wow, that's impressive. This makes building a Tear look like child's play.
Are you journaling your aircraft build anywhere? There's at least 2 people here (KC & me) that would like to look over your shoulder.
Thanks I saw your handywork on your trailer frame build. I was really tempted to build an aluminum tear to pull behind my motorcycle but I have to many long term projects right now so...RandyG wrote:+1 here on the aircraft eye candy!
KCStudly wrote:Those are fairly complex, even with a CNC router and CAD. Nice.
vtx1029 wrote:No worries on the clamp. Been there done that.
vtx1029 wrote:Did you know that you can cut thru drywall screws
vtx1029 wrote:Was there a reason why you didn't connect your vectors while cutting the outside profile on those parts and just run it as a single toolpath? It would have saved you a bunch of time.
vtx1029 wrote:What bit are you running there a compression spiral?
capnTelescope wrote:vtx1029 wrote:No worries on the clamp. Been there done that.
My guess is that anyone that hasn't, hasn't used clamps. Several of my clamps have hickeys on them. I always do a dry run an inch high with the laser on to check for that kind of thing, but the laser won't tell you where the collet is going.vtx1029 wrote:Did you know that you can cut thru drywall screws
I know that a dado blade will. I also know that if you try to rout thru a washer, the washer wins.vtx1029 wrote:Was there a reason why you didn't connect your vectors while cutting the outside profile on those parts and just run it as a single toolpath? It would have saved you a bunch of time.
Ummm. I've run into this situation where I did that and disconnected the part from all clamping before I got all the way around. I don't quite have CamBam under control yet. Since the CNC is my personal toy, I don't worry too much about optimizing g-code for cycle time. Plus, I'm only making onesie-twosies most of the time, so it takes less time overall (programming + cutting) to not stress over optimization. OTOH, it is much more fun to watch a well-optimized program run.vtx1029 wrote:What bit are you running there a compression spiral?
It's a Bosch downcut, available at Lowe's for cheap. It works better than the Freud (available at HD), IMHO. I haven't tried a compression bit, yet. For one thing, bit longevity was pretty short at first. (See routing thru a washer, above.) And they're not available locally. And they're a little more spendy. Excuses, excuses. Next trip to Woodcraft, I'm putting one on the shopping list.
Thanks for stopping by!
vtx1029 wrote:Can cam bam do tabs?
KCStudly wrote:It's a start! ...
KCStudly wrote: If you stare right at the arc you can lose the line.
KCStudly wrote:... the tacks are more visible and can also be a guide.
KCStudly wrote:Don't forget to factor in the fact that you will need to flip your frame several times...
