tlsallada wrote:Romex cable is perhaps a bad choice for wiring a vehicle as the solid conductors will tend to break due to vibration over time. I used a 14 gauge extension cord with stranded wires in my build. The stranded wire will resist breakage and will be easier to run. The average home uses 14 gauge wire for many circuits and will handle almost any load to be encountered in a trailer. You could use this for both your AC as well as your DC circuits.
terry
GuitarPhotog wrote:Thousands of RVs and travel trailers have been wired with Romex by their original manufacturers. If it wasn't safe they wouldn't use it.
<Chas>
GuitarPhotog wrote:tlsallada wrote:Romex cable is perhaps a bad choice for wiring a vehicle as the solid conductors will tend to break due to vibration over time. I used a 14 gauge extension cord with stranded wires in my build. The stranded wire will resist breakage and will be easier to run. The average home uses 14 gauge wire for many circuits and will handle almost any load to be encountered in a trailer. You could use this for both your AC as well as your DC circuits.
terry
<Chas>
MtnDon wrote:GuitarPhotog wrote:Thousands of RVs and travel trailers have been wired with Romex by their original manufacturers. If it wasn't safe they wouldn't use it.
<Chas>
Beat me to it.... We've had assorted factory made Class C's over a few decades and they all had solid wire 120 VAC and none had any issues with any AC wiring.
Solid wires can be more difficult to run through curves and bends.
Stranded wire can be more difficult to secure to some devices... such as properly securing stranded to a side terminal where the wire must be wrapped around a screw and the screw tightened. Mpst devices can be used with stranded, but not all. Check the specs.
bobhenry wrote:No one has mentioned extension cord wire yet! I built chubby with 12-3 extension cord wire and was happy with having the extra sheath over the wire, It is stranded wire and flows and bends very easy. I went a step further and used vacuum cord wiring salvaged from old vacuums left at the curb for the DC. Most have simply two wires black and white so color coding for the DC is easy.
Dale M. wrote:Do internet search for "Plastic Raceway" .... Great stuff for surface mount applications...
Dale
brandon32689 wrote:bobhenry wrote:No one has mentioned extension cord wire yet! I built chubby with 12-3 extension cord wire and was happy with having the extra sheath over the wire, It is stranded wire and flows and bends very easy. I went a step further and used vacuum cord wiring salvaged from old vacuums left at the curb for the DC. Most have simply two wires black and white so color coding for the DC is easy.
How did you run your wires
brandon32689 wrote:Dale M. wrote:Do internet search for "Plastic Raceway" .... Great stuff for surface mount applications...
Dale
I've been looking at that to where is the best place to get it at, and would you just run individual wires threw it.
Kharn wrote:I just ordered raceway from monoprice.com, it was dirt cheap compared to other sources that I found, especially for the connectors/corners/etc, like $0.19 each instead of $5 for 5.
