The Monstero Build
Re: The Monstero Build
Postby nevadatear » Thu Sep 11, 2014 10:34 pm
Yes, actually i sanded down the entire side as i was getting it ready for varnish and it was not smooth after the last epoxy coat and really needing to be smoothed out. I wanted to do the majority of the sanding while it was flat.
nevadatear
Images: 171
Postby Mike46 » Thu Sep 11, 2014 11:19 pm
Debbie and Randy, good tips, thanks for the help.
Mike
Mike46
Images: 15
Postby nevadatear » Fri Sep 12, 2014 6:30 pm
Mike, this is debbie and i knew nothing about epoxy until this build. I got all my info from Steve Fredrick's shop manual on teardrop building. Randy doesn't do finish work so all the epoxy and varnish or poly finish as well as sanding was my job.
nevadatear
Images: 171
Postby Mike46 » Fri Sep 12, 2014 7:02 pm
Debbie, thanks I'll look into Steve's manual. By the looks of it, you did a great job without Randy.
Mike
Mike46
Images: 15
