Timbren Axel-less axels?
Postby Thelgord » Sun Feb 22, 2015 4:43 pm
I know I don't post a lot on here, but I do lurk a lot. I was just curious if anyone has every tried these: http://timbren.com/axle-less/
I like the idea, but I don't know much about them.
Thelgord
Re: Timbren Axel-less axels?
Postby lrrowe » Sun Feb 22, 2015 4:46 pm
I believe I have seen a few posts or images posted here. Try the search feature for them. Good luck and welcome to posting her.
Bob
lrrowe
Images: 439
Postby glenpinpat » Sun Feb 22, 2015 7:55 pm
I have installed them on my present build. Though I have not finished building my trailer I took the trailer loaded with wood for a trip around Michigan and was very pleased with the ride. I could barely tell the trailer was behind me even with 500lbs on it. They were also very easy to install. You can see pictures of my build on the tearjerker site just look for spielhaus under the build projects section.
glenpinpat
Postby tony.latham » Sun Feb 22, 2015 10:27 pm
I plugged in "timbren" into the Google search block and got 26 hits. 8)
T
Postby Thelgord » Sun Feb 22, 2015 11:45 pm
glenpinpat wrote:I have installed them on my present build. Though I have not finished building my trailer I took the trailer loaded with wood for a trip around Michigan and was very pleased with the ride. I could barely tell the trailer was behind me even with 500lbs on it. They were also very easy to install. You can see pictures of my build on the tearjerker site just look for spielhaus under the build projects section.
Tearjerker site?
Thelgord
Postby Dale M. » Mon Feb 23, 2015 10:15 am
Dale M.
Images: 18
Postby kayakdlk » Tue Feb 24, 2015 7:17 am
kayakdlk
Images: 392
Postby Thelgord » Sat Feb 28, 2015 11:46 am
kayakdlk wrote:My Experience for my build http://www.tnttt.com/viewtopic.php?f=35&t=57134
Dan
Thanks for the information :) Very helpful :)
Thelgord
Postby javajaws » Sat Mar 07, 2015 8:45 am
I'm using them, but still in the building process. Solid piece of hardware, no major issues so far other than the fact I couldn't find the toe adjustment instructions and had to call their support line to help show how much of an idiot I was (they were on the back side of one of the instruction pages I already had). At any rate, their support guy also emailed me a pdf copy.
Here is my build thread (in progress):
http://www.tnttt.com/viewtopic.php?f=50&t=62493
javajaws
Postby javajaws » Sat Mar 07, 2015 8:47 am
Dan
Did yours ever settle in and even out the camber? Did you use any/all of the shims supplied?
Mine still has some positive camber with the shims - but it doesn't really have any weight on it yet either. Was just curious.
javajaws
Postby jss06 » Mon Mar 23, 2015 7:22 am
I just purchased a set to retrofit my trailer. Finished the brackets for the inside this weekend. Hopefully will be able to get it completed by next weekend.
jss06
Palladium Donating Member
Postby capnTelescope » Wed Mar 02, 2016 8:11 pm
Bump. See my post about changing the rubber spring on a Timbren: http://www.tnttt.com/viewtopic.php?f=35&t=65537
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
