My build of Benroy Style Trailer
Re: My build of Benroy Style Trailer
Postby AlgoDan » Thu May 22, 2014 6:14 pm
Starseeker wrote:Have you noticed any real benefit to having the back of the trailer squared off?
Aaron I basically went with this design to utilize all the space I could squeeze out of it. As I like the space..
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby wyrdone » Tue Jan 20, 2015 9:47 pm
Hey can we get a picture or drawing of how your galley was laid out? :D
wyrdone
Postby AlgoDan » Thu Jan 29, 2015 8:25 pm
wyrdone wrote:Hey can we get a picture or drawing of how your galley was laid out? :D
102689Here is a photo from my gallery, hope this helps.
Build Journal
AlgoDan
Images: 238
Postby mrwall1 » Thu Feb 05, 2015 11:22 am
Hey Dan, since I pretty much copied your build! what size rear hatch struts did you use? I haven't installed any yet, but am getting tired of holding it up with one hand while I put a pole under it.
thanks
mike
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Postby AlgoDan » Tue Feb 17, 2015 6:42 pm
mrwall1 wrote:Hey Dan, since I pretty much copied your build! what size rear hatch struts did you use? I haven't installed any yet, but am getting tired of holding it up with one hand while I put a pole under it.
thanks
mike
Hi Mike, I started with 27lbs then went 42 lbs still not enough then went with 57 lbs and it opens just beauty, hope that helps.
Build Journal
AlgoDan
Images: 238
Postby mrwall1 » Tue Feb 17, 2015 7:49 pm
Thanks!! Sounds good!!!
Mike
mrwall1
Postby AlgoDan » Tue Mar 03, 2015 5:02 am
mrwall1 wrote:Thanks!! Sounds good!!!
Let me know how it goes Mike.
Build Journal
AlgoDan
Images: 238
Postby glake » Sun Jun 21, 2015 4:35 pm
You're trailer turned out great. I've been reading through a lot of builds over the years and am finally started my own. You've given me lots of ideas. Thanks for sharing your build.
Build Journal: Woody's Wagon
glake
Images: 20
Postby AlgoDan » Sun Jun 28, 2015 5:09 pm
glake wrote:You're trailer turned out great. I've been reading through a lot of builds over the years and am finally started my own. You've given me lots of ideas. Thanks for sharing your build.
Thanks glake, I too read many builds and built away. Good luck and post pics.
Build Journal
AlgoDan
Images: 238
Postby clock152 » Tue Aug 04, 2015 8:20 am
This is such a great build. Exactly what I want to do. How hard was it to get that mattress in there?
clock152
Postby AlgoDan » Mon Aug 10, 2015 5:52 pm
clock152 wrote:This is such a great build. Exactly what I want to do. How hard was it to get that mattress in there?
Thank you. Getting the mattress in wasn't hard, I built an access panel below the counter which is the width of trailer, it is hinged and we just slide it in.
Build Journal
AlgoDan
Images: 238
Postby rebapuck » Wed Aug 12, 2015 11:35 am
That's forward thinking.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby AlgoDan » Thu Aug 13, 2015 5:12 am
rebapuck wrote:That's forward thinking.
Thanks, sometimes you have to plan it out so everything flows.
Build Journal
AlgoDan
Images: 238
Postby ai4kk » Fri Jan 22, 2016 3:16 pm
Just like I plan to make my entire kitchen box removable, partially so I can put a real mattress in from the back, but also so I can take the kitchen out and use it elsewhere...picnic table or shelter, inside a cabin or motel room etc
Gene
ai4kk
Images: 9
Postby retep » Fri May 27, 2016 10:25 am
Great Build. I just wanted to share my thanks for sharing it here. You and so many others are so inspiring by posting it here. Think once I finish rebuilding the kitchen I will start my Benroy before the Mrs finds another major project.
Thanks Again.
retep
