space saving furniture
Re: space saving furniture
Postby bobhenry » Wed Feb 11, 2015 10:23 am
I found an absolutely brilliant cutting board and waste basket combo.
Images: 2617
Postby GerryS » Thu Feb 12, 2015 5:34 am
Looks nice....but I see at least three problems. Fist, you you have to sacrifice drawer space...look at all the hollow space under the board. Second, how would you wash it? Third, the cutting board (which is hard to wash) is right above a bacteria factory.
GerryS
Postby bobhenry » Thu Feb 12, 2015 5:43 am
What don't kill ya makes ya stronger !
Images: 2617
Postby bobhenry » Thu Feb 12, 2015 7:55 am
GerryS wrote:Looks nice....but I see at least three problems. Fist, you you have to sacrifice drawer space...look at all the hollow space under the board. Second, how would you wash it? Third, the cutting board (which is hard to wash) is right above a bacteria factory.
OCD is associated with above-average intelligence.[1]
Make me glad I just ain't too smart !
Images: 2617
Postby wagondude » Thu Feb 12, 2015 5:30 pm
So, to address the issues that Gerry pointed out, make the same setup to fit over a sink bowl. Place a catch bowl in the sink under the hole in the board ( you are going to compost those veggi scraps or maybe feed them to the chickens, right?). The board stores normally, as does the bowl. Easy to clean and no lost drawer or cabinet space.
Bill
101137
wagondude
Images: 35
Postby S. Heisley » Thu Feb 12, 2015 11:43 pm
wagondude wrote:So, to address the issues that Gerry pointed out, make the same setup to fit over a sink bowl. Place a catch bowl in the sink under the hole in the board ( you are going to compost those veggi scraps or maybe feed them to the chickens, right?). The board stores normally, as does the bowl. Easy to clean and no lost drawer or cabinet space.
:applause: :applause: You've got it! :yes:
Postby bobhenry » Tue Mar 24, 2015 11:46 am
Lookey lookey what I found......
Kinda neat Huh !
Images: 2617
Postby jss06 » Tue Mar 24, 2015 3:14 pm
That is cool.
jss06
Palladium Donating Member
Postby bobhenry » Wed Apr 29, 2015 10:12 am
This got me to rethinking the foot stool storage hassock idea. Pinned in a rack or between exposed studs they can become shelves. Arranged on the floor with the padded seat in place they are the couch or individual seating and shoved together again the bed. What a great idea.
Images: 2617
Postby mezmo » Sat May 02, 2015 2:07 am
That hassock set up is a good idea, but with a couple of caveats,
based on past experience with a similar set up. First, it is very important
that the hassocks would be mechanically joined together somehow so that
they do not come apart. Gravity and friction alone will not do it. Second,
it is imperative that the foam padded tops are also securely located so
that they can not move when used for sitting and sleeping. If they are not
secured, they are guaranteed to separate/move and go to the side and you
will end up laying on the plywood top or in the hassock.
Cheers,
Norm/mezmo
mezmo
Images: 194
