Well, to be honest, it only works that well when I add in the Yoyodyne Propulsion System Dimensional Modulator. In reality, many of my ideas come from YPS. Just remember...
The Future Starts Tomorrow!
dave
daveesl77 wrote:Finally got around to uploading a couple of pics. Installed the EPDM and PMF (Poor Man's Fiberglas)
Today I took down the giant tarp/canopy rig (also called my temporary build shelter) so I could install the EPDM on the roof. Canvas/TB2/Paint covering is on the front and rear, EPDM across the top.
Front and rear canvas glued on and 1st coat of paint. EPDM laying on top getting hot and ready for installation.
EPDM glued down, initial trim cuts on all facing material cut. I used the latex adhesive with the EPDM, as advised here and WOW it is easy to do with that!
There will be several wood trim pieces running across and then I'm hoping to steam bend the outer trim boards. Haven't steam bent wood in about 30+ years, so hopefully I remember how to do it. If not, then I'm about to wreck some expensive hardwood. Aluminum sheet runs across the base of the front section as a rock guard.
Got the first paint coat sanded and a second coat put on today. Tomorrow I'll sand it down again and put on a 3rd. Will probably have 4 coats when done. Fingers cross that the latex adhesive on the EPDM is cured by tomorrow so I can bend in the overlap and adhere.
This is the first time the trailer has been out in the sun, but it is now covered back up again. Next up is the door trim and wiley windows.
dave
