If I chose to run a window ac off this system and installed an inverter how long would the system last?
MtnDon wrote:In normal use AGM do not vent. They are made to vent so they don't explode if abused. You do not want them to vent as there is no way to replace electrolyte. Venting is detrimental to their longevity. In normal use they don't vent and can last a long time. You pay for that "no need to ventilate" with the higher purchase price. Don't abuse and they have advantages, for the $$.
MtnDon wrote:Depends on one's level of paranoia...
Under "normal" use an AGM is very safe. There are doomsday scenarios in which an AGM can actually melt down, cause a fire. But that is very rare. Not something most of us will ever encounter. I would be comfortable installing an AGM inside my trailer if one would meet all my requirements.
MtnDon wrote:Well, what to say? That is an AGM version of the typical RV / Marine deep cycle battery, in a group 31 size. Not really a true deep cycle like a golf cart battery, GC-s group size. Better than a typical cranking battery sold for standard automotive use, but not as robust as a golf cart battery. Not as much weight as two GC-2's; because it is not as good, contains thinner lead plates.... Last time I checked it is made by Deka, an reputable manufacturer.
What it probably comes down to is if one does not want to cart around the weight of two FLA or AGM GC-2's and if one does not need the extra AH capacity offered by two GC-2's or spend as much money as two AGM GC-2's..... that group 31 AGM will do a creditable job as long as it is not overtaxed. IE don't do high amperage discharges as in running a 1500 watt electric kettle for 6+ cups of water every day. I would likely be happy if I was running lights, a water pump, fans... that sort of thing.
