how many amp hours are you planning on using per day?
How exactly are you planning on using your system? Shore power vs battery only etc....
TNSean wrote:how many amp hours are you planning on using per day?
Wobbly Wheels wrote:The cooler won't draw 4A all the time, only when it's cycling. It will take some time to figure out how much it actually draws over 24hrs. That will go up as the outside temperature does as well. You can cut that down by putting a jug of frozen water in there if you can spare the space for it. If it has extra insulation around it, it will also cycle less.
Wishno wrote:Hey guys I started getting my electrical system together today and I noticed that when I plugged in my cooler the plug for it got kind of hot and didn't run as fast as it does when it's plugged into my jump box. I ran 14 gauge wire to it and a 15 amp fuse. Do I need to run bigger wire to it?
