I'm making a trailer drawing to be fabricated. I would love input on it.
http://wulfheir.com/pics/TRAILER-Model.pdf
angib wrote:
You will need to use a (industry standard) 50deg A-frame coupler instead of a straight one, though that will give you the mounting hole for a screw jack for free. You also need to deal with the slightly awkward tube-to-angle joints at the back of the tongue - one thing to consider is whether you would like to orient the perimeter angle with its vertical leg to the inside, as this makes the frame less visible. You also need to add one or two pieces of angle either side to make the seat for the axle to mount to.
Andrew
