Diemjoe wrote:Thanks Mike,
I did know about the conversion inefficiency but it does make sense. I a going pretty light on the power usage. Just charging tele, computer and blue tooth speaker. So it will be a light draw. At the same time, your right, I just need to snip a wire on the LCDs and run another cable. Time for bed to sleep on it.
Don
Diemjoe wrote:Does anyone have a wiring diagram for connecting the inverter so that I can switch between shore and inverter power source?
lfhoward wrote:There is a device called an automatic transfer switch...
