welder...
welder...
Postby BigDaddyCool » Sat Jun 17, 2006 11:26 pm
i'm thinking of buying a new ( more powerfull) welder, so what did you use for your tear :thinking:
since i'm a welder/fabricator for a truck trailer company , welding is no secret for me 8)
just wana know what your welding whit ;)
BigDaddyCool
Postby doug hodder » Sat Jun 17, 2006 11:36 pm
I sold my gas welder when I moved, but bought a Lincoln WeldPak 100...for around the house/yard, no commercial use...gasless...has enough poop to do the frames I want to do....no fatigued welds/falilures or problems on either one, over 6K miles on #1, it's just a year old...3 miles on #2 in and out of the shop a lot!! :lol: ...also takes up a lot less space in the shop, but I do miss aluminum gas welding capabilities.... :thumbsup: Doug
Postby Leon » Sun Jun 18, 2006 12:13 am
Miller Syncrowave 250 TIG.
Leon
Images: 21
welder
Postby jdsackett » Sun Jun 18, 2006 5:54 am
miller dvi. holds 2 bottles. argon / argon-co2. change plugs for 110 ot 220 input. has a switch and diverter valve to switch from spool gun to steel gun. sweet machine
i am NOT cheap. inexpensive maybe, but not cheap
jdsackett
Postby emiller » Sun Jun 18, 2006 8:20 am
A Miller 130xp and a Miller 250. What else what a Miller buy.
emiller
Images: 157
Postby BigDaddyCool » Sun Jun 18, 2006 8:21 am
i want too keep the cost low so i was tinking Lincoln AC225 stick welder :thinking:
BigDaddyCool
welder
Postby jdsackett » Sun Jun 18, 2006 8:52 am
good machine bigdaddy. still have one in the shed i bought in the 70s and it still works. just got lazy when migs came out i guess
jdsackett
Postby Chris C » Sun Jun 18, 2006 9:13 am
I welded my frame with oxy/acetylene....................and sure wish I'd had a wire-feed welder. I warped my frame from front to rear and have had a dickens of a time pulling it back to plumb. Think I'll use my oxy-acetylene rig for cutting only in the future. :lol:
Chris :D
Chris C
Postby Steve_Cox » Sun Jun 18, 2006 9:18 am
Got an ancient Lincoln 225. Made a rod box out of an old mailbox, I put a 15 watt light bulb in the back of it to keep my welding rods dry.
Steve_Cox
Images: 196
Postby Cutterpup » Sun Jun 18, 2006 12:46 pm
Welder what welder I used duct tape. It has a light side and a dark side and holds the world together
Dan
I used an acient craftsman buze box 230 amps and never went over 100 amps
Dan
Cutterpup
Images: 15
Postby sunny16 » Mon Jun 19, 2006 10:37 am
Millermatic 175 220V with gas. Tried the cheap HF 110v wire feed but the welds were terrible and didn't work good on the thicker stuff.
I cut it three times and it's still too short!!
Perfection is all I ask.......
sunny16
Images: 70
Postby IndyTom » Mon Jun 19, 2006 3:11 pm
Model 151 from HF. Not the best, but it did all I ever asked of it when I was welding my frame. It may die tonight, but it has served me well so far. With 20% off coupon and HF's perpetual sales, should be able to get it for $160 or so.
Never trust a skinny cook
IndyTom
Images: 42
Postby TRAIL-OF-TEARS » Mon Jun 19, 2006 4:23 pm
Used a Lincoln DC stick welder. Took a welding class a few years ago and the teacher could do anything with a stick welder and a cutting torch.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby Nitetimes » Mon Jun 19, 2006 4:38 pm
Lincoln 175 MIG ... 220v ... none of the smaller ones will do what I need them to and this one is even a bit small for me. 8)
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby hammer & tongs » Mon Jun 19, 2006 7:35 pm
Since i am a blacksmith, I weld with electric, oxy/acet and occasionally some forge welding.
My electric welder is "old dependable"..an early seventies Lincoln 225 (copper wound)..
I decided , a couple years ago to get a MIG welder..so I went to a big-box store and bought a no-name unit...
BIG MISTAKE !!...If I were to do it again, I would spend the same money and buy a 10 year old BRAND NAME...
That no-name sits in the corner..collecting dust...
" By whose stripes you were healed ."
(1 Peter 2:24b )
hammer & tongs
Images: 9
Users browsing this forum: Google [Bot] and 3 guests
