Unusual Designs Found on Internet
Ref page of lateral pop top
Postby WizardOfOdds » Sat Jun 25, 2016 8:57 pm
I located the reference page for the build of this trailer,
you can read all about it at this link
http://homemadecamper.com/
or read about this build
here on this site here
http://www.tnttt.com/viewtopic.php?f=5&t=47647&p=959651#p959651
WizardOfOdds: Chalet shaped rag roof clam shell TIER drop for 4 cylinder tow
Tip Top Tier Drop thread http://www.tnttt.com/viewtopic.php?f=5&t=56232
Unusual Designs thread http://www.tnttt.com/viewtopic.php?f=5&t=64495
Tale of 2 Trailers thread http://www.tnttt.com/viewtopic.php?f=35&t=61451
WizardOfOdds
Images: 43
Postby Ned B » Sun Jun 26, 2016 10:35 pm
WizardOfOdds wrote:Ned B wrote
I especially like the zigzag roof RV, very similar to a foamie that I've got plans for.
I like the Zigzag configuration too. While building the (first version of ) Tip Top Tier Drop, I considered the half roof dormer configuration, like this one
because it reduced the effort needed to lift the combined roofs from the rear, but it also shifted too much of the weight forward of the axle. I also worried about highway lift, wind and rain the front edge of the top roof had to deal with when closed. In the end the gains did not seem to warrant the added complexity.
Notice the commercial trailer
has a solid roof and fabric sides. I prefer the exact opposite. But if you are OK with fabric sides, I think it would not be hard to build. For one, the fabric sides have no complex pattern to sew.
How are your plans progressing?
Well I got pretty far in sketchup. This is my 'big' trailer a wild goose in foam. It is on the shelf for now. Instead My first build is going to be a much simpler Foamie, closer to a Kenskill . A one person sleeper vs a three plus person lifting roof with amenities.
Ned B
Interesting Trailer, Interesting Brake
Postby WizardOfOdds » Tue Jun 28, 2016 1:18 pm
edit 7/24/2017
Sorry, the links below have gone bad.
Note: Picture too big for your window ?? Try this: Hold down "CTRL" and hit MINUS SIGN several times. To return to normal size font, use CTRL & "+" (plus sign).
This is cute, but I can see myself chasing the roof down wind after forgetting to never have both sides unhooked at the same time ...
partially up rear view
field views
full up front view, check out the interesting hitch connection and mechanical brake
kitchen
bed
ready to roll
article
read about it here
http://www.ebay.co.uk/itm/UNIQUE-VINTAGE-CLASSIC-OLD-1951-WANDERER-FOLDING-CARAVAN-VERY-RARE-/121735589716?nma=true&si=96SlbbMUBtBh4BVqqeD6f4jaFEA%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
WizardOfOdds
Images: 43
Back Porch Pod
Postby WizardOfOdds » Mon Jul 11, 2016 11:19 pm
Better make sure your hitch and weight distribution is right with this one
Read about it here http://www.30secondstocamp.com/
WizardOfOdds
Images: 43
Re: Unusual Designs Found on Internet
Postby OP827 » Tue Jul 12, 2016 6:56 pm
I like this thread, thanks for doing it. Here is Eco-tourer from Australia
with optional bathroom
OP827
Images: 405
EziVan
Postby WizardOfOdds » Sat Jul 16, 2016 10:14 am
Yes, the Eco-tourer is interesting. Australia has a lot of interesting folding trailers. I think the EziVan is also from down under.
Read about it here http://www.caravanningnews.com/ezivan.htm
and catch a video at http://www.abc.net.au/tv/newinventors/txt/s3008702.htm
WizardOfOdds
Images: 43
Douglas Fir lift roof slide-in
Postby WizardOfOdds » Tue Jul 26, 2016 11:15 pm
How much wood would a wood trucker truck, ....
apparently 1200#s. Made with 2x6 solid Douglas Fir planks, plywood delamination is not a worry.
Alternate door with kitchen storage
Read the details at
http://www.doityourselfrv.com/self-made-pop-camper-built-douglas-fir/
and
http://www.instructables.com/id/Self-made-Wooden-Camper-Kleine-Cabine/
edit 30 july 2016:
Opps, it turns out mnormand posted a photo of this on this forum earlier at this link
http://www.tnttt.com/viewtopic.php?f=5&t=66225
I don't like to repeat things already posted and considered deleting it from here, but decided to leave it because this includes links to the story.
WizardOfOdds
Images: 43
mini bottom hinged, rag side clam shell
Postby WizardOfOdds » Sat Jul 30, 2016 12:36 am
WizardOfOdds
Images: 43
more on Double Side 3x Expansion
Postby WizardOfOdds » Tue Aug 02, 2016 9:09 am
When I first posted (page 1) the CAD picture of this design, I never expected to see actual hardware in action. But here it is
and here is a full tour
or catch the slide show from here
http://www.gizmag.com/beauer-3x-expandable-teardrop/38991/pictures
It may look like a simple idea, but start thinking over the details of actually getting one to work :roll:
WizardOfOdds
Images: 43
PopUps Old & New Video
Postby WizardOfOdds » Fri Aug 05, 2016 8:07 am
WizardOfOdds
Images: 43
Re: Back Porch Pod
Postby BigGoofyGuy » Sat Aug 06, 2016 1:20 pm
WizardOfOdds wrote:Better make sure your hitch and weight distribution is right with this one
They sent a reply indicating they will have a version that is on a trailer instead of the hitch; IIRC. I think that would be great for cars that don't have hitches that conform to the requirements of this camper.
BigGoofyGuy
Location: Newburyport Massachusetts United States of America
side opening clamshell
Postby WizardOfOdds » Wed Aug 17, 2016 8:44 pm
This side opening clamshell seems to use fabric for the opened sides. Top might be a heavy lift (even though the top section is shorter than the bottom - why??), so foam might be a good choice for the top tier. The protruding door frame & slanted wall could be avoided by some mods, but I like it the way it is. For better highway airflow, consider beveling the top end(s).
from here http://gypsyjournalrv.com/author/administrator/page/51/
WizardOfOdds
Images: 43
Postby OP827 » Fri Aug 26, 2016 9:31 pm
Another design Ecotourer 420, looks like a teardrop when in transport mode. Found here - http://www.caravans.com.au/Eco420.html
OP827
Images: 405
Postby OP827 » Sun Sep 04, 2016 4:34 pm
This is a custom made aluminum lifting roof trailer.
Building thread of its structure is here: http://www.ranger-forums.com/fabrication-tool-tech-42/off-road-hard-sided-popup-trailer-133614/page3/
Its roof is lifted by electric actuators in each corner, 4 total.
OP827
Images: 405
Postby greygoos » Sun Sep 04, 2016 9:19 pm
Here is a bug out for when the Zombies take over
greygoos
