Well, I had a lot going on this weekend so I didn't really get anything directly related to the 'drop done, but I did pick up something that should help things going forward.
I found this baby on Craigslist about 40 minutes from my house:
It's a Ridgid TS3650 Contractor's Tablesaw. I picked it up for $200. Except for the rusty top is in really good shape. Looks like it's done more sitting than sawing. Once I get it cleaned up I think it'll be a nice saw again.
I started by hitting the high spots with a paint scraper.
After that, I coated the top in 3-in-1 oil and let it sit overnight.
Last night I came back and soaked it heavy in PB Blaster. After a few hours, I got out the belt sander and went over it with 80 grit on low speed. I kept it wet with PB Blaster as I sanded.
After I finished going over it with 80, I hit the pitted spots with a wire cup brush in the cordless drill until I got what discoloration out of it that I could. Sorry for the lack of pictures, I just didn't want to deal with taking off the greasy gloves that often.
After that, I switched to 120 grit in the belt sander and wet-sanded with PB again at about half speed.
Starting to look decent at this point. Hit the discolored spots some more with the wire cup brush, then wet 120 on high speed.
Finally, I switched to a sanding block with 180 grit, and wet sanded it for probably 10 minutes. Here's where I stand after last night's efforts.
Looks decent, and it's actually very smooth. 180 is the highest grit I had, except for my palm sander. Didn't want to go that route, as I only want to sand directionally front to back. I'll try to grab something like 240 and 400 today and see if I can finish it up tonight.
I still need to sand the T-slots also, then degrease the whole saw after making a terrible mess wet sanding. After that, a good coat of Paste Wax and I think she'll be good to go... At least good enough to start tuning it up.
Sent from my Nexus 6P using Tapatalk
