drgrumpus wrote:This is such a great topic. Lots of good info from other builders. I am going to put 1/16(.063) aluminum diamond plate on the front (modified Grumman II profile) as a stone guard over my two layers of 1/8 Baltic birch. A local sheet metal shop can roll form it to my template. That will save me the hassle of bending it myself.
I plan to put two coats of CPES on the BB, then attach the Al with screws through enlarged holes. I'll use SS washers under the screw heads and only snug them, which should allow the Al to expand/contract. I'll put silicone caulk under the edges of the plate. It should be flexible enough to allow for expansion. I will leave a few gaps in the caulk at the bottom to help drain away any water that does get in.
Comments?
I checked your profile credentials, Dr. Grumpus, and I see you're a retired aerospace engineer. I'm only a lowly college graduate in mechanical engineering, so I may be way off with this
... but ....
If you plan to float your aluminum skin, and you firmly fasten the perimeter of the aluminum, doesn't that allow the remainder of the sheet to expand/contract freely in the orthogonal direction? Basically, it can "oil can" when hot, and shrink back to flat when cold. Now, your idea was to only snug the fasteners and allow the aluminum to expand/contract in a planar direction, which would seem to convert all the force of thermal expansion into bearing stresses at the screw/aluminum interface. Since aluminum is so much softer, would this just deform the sheet metal and lead to possible water leaks?
Wait a minute ... you plan to attach the aluminum with
enlarged holes. Ah ha! (I'll still post this comment in case anyone else had the same concern). So that takes care of the bearing stresses, and you're assuming that the washer is large enough to cover up the hole and prevent water intrusion. Good idea! Any reason why you're going with a stainless steel washer over a rubberized one, like on a roofing screw?
