KCStudly wrote:I like the West System because they provide a ton of use information on their website, and I believe that I should reward them with my business for that (rather than stealing their info and using a cheaper brand).
However, there is nothing wrong with using the PL300, just plan on making a bunch of shallow kerf cuts and leaving these open while the big stuff cures. From there you can plug or seal the ends of the kerfs and move on.
Finally, my experience isn't the last word on this. Others have used varying methods and materials successfully. Your climate may give you different results. Just remember, when testing this kind of thing you need to do a large enough test piece to be representative of the actual conditions; small scale tests might work fine because there was good proximity to air and/or moisture.
