bobhenry wrote:It is a lot less of a hassle to simply find a threaded both with the same thread pattern and size and cut off the head then grind it down to a bullet shaped nose. Put it in with your fingers hang the rim and install the lug bolts remove the "alignment pin" and put in the last lug bolt. store it with the jack and you have no more problems.
KCStudly wrote:I'll take that idea and suggest a potential improvement. Why not use a long set screw, a very large set screw, as the temporary guide pin? That way you can use an Allen wrench to back it out if it becomes finicky.
Here's an example: http://www.mcmaster.com/#91375a742/=14c394g (verify your thread size).
bobhenry wrote:Perhaps if you were good with a welder this feature could be added by drilling the rim and where the bit starts to mark the hub is where this indexing pin needs to be welded on.
MtnDon wrote:Whatever you do keep in mind that with most (all?) trailer hubs and wheels of this type (bolt threads into flange) the entire weight of the trailer is being supported by the bolts. There is no center hub and flange like on an auto wheel and hub. So the bolts / studs must be rated for the use.
I just changed a wheel/tire on my utility tailer. It has bolts into the hubs. I have always found it relatively easy if the axle is only jacked just enough. Then I sit on the ground and use my feet as guides or supports while I thread in the bolts.Once you have 2 in place the rest are easy.
Aaron Coffee wrote:If there is a dexter axle dealer nearby they should have screw in studs(tsc, bomgaars, also may carry them). A little lock tite on the end that threads into the hub, and you now have studs instead of bolts, you will also need lug nuts.
