Off Road Grumman 2ish (5x5x10) Build
Re: Off Road Grumman 2 (5x5x10) Build
Postby KCStudly » Tue Nov 15, 2016 7:36 pm
DWT77 wrote:I didn't find any that were wider than 10 inches. I would of liked a 12 inch fender. Given the time I spent with these fenders, I probably should of got some 1 inch tubing, 14 gauge sheet metal and try to make them myself.
That's the same boat I am in. I wanted flat top fenders, but the Jeep style is a little peaky. With 31 inch AT's and generous side wall clearance to the cabin, the 10 inch width has to be spaced out from the cabin wall to just barely cover the tread.
I thought about buying a third fender, sectioning all of them to make them wider, and then modifying them to stretch, as you did, but that is as much, if not more work than just starting from scratch; probably more expensive in the end, and likely harder to make come out nice dealing with warping and blending all the welds.
Postby DWT77 » Wed Nov 16, 2016 5:37 pm
I probably should of just went with something like this
https://www.youtube.com/watch?v=FsLyt95A9Kw
DWT77
Images: 473
Postby Andrew Herrick » Wed Nov 16, 2016 11:41 pm
Love watching your progress. I don't think I saw this mentioned earlier ... but why the extra-long tongue? Most tongues range from 36 to 48 inches ... and I think yours is a fair bit longer. Just curious :)
A few of my builds:
Andrew Herrick
Images: 15
Postby KCStudly » Thu Nov 17, 2016 12:05 pm
DWT77 wrote:I probably should of just went with something like this https://www.youtube.com/watch?v=FsLyt95A9Kw
Those are really nice! I like the tapered front and rear. I think I can do it a little lighter, tho. With access to a break press for forming the curled lip I can omit the tubing. Will do mine in aluminum. May not be as robust, but will suit my needs just fine. I might just steal that guy's look, tho. I like it. Thanks for posting.
Postby DWT77 » Thu Nov 17, 2016 6:56 pm
Andrew Herrick wrote:Love watching your progress. I don't think I saw this mentioned earlier ... but why the extra-long tongue? Most tongues range from 36 to 48 inches ... and I think yours is a fair bit longer. Just curious :)
I am going to build a 48 inch wide by 24 inch long box on the front, which is a fairly good size box. It will have 2 compartments (top/bottom). The bottom compartment will be 18inches tall. The door will be able to open forward to lay flat on the tongue (will come just short of the trailer jack). I wanted easy access to my generator, climate right, ect... The top will house all of my electronics and battery.
I looked up the dimensions/weight for all of the items I want to have in the trailer including 12v freezer in galley ect. Took the trailer balance spreadsheet added the weight in the appropriate places. Which gave me a heavy tongue, so I adjusted the timbren axles up 2 inches and that gave me my 12-13% tongue weight.
Hopefully the tongue won't look so long and naked when completed.
My overall goal was to have a trailer that I can do some decent off roading and boondocking in. Make a base camp to do some day hiking or even a multi day trip then return. The trailer will probably end up being a little on the heavy side but hopefully will do most of I need.
DWT77
Images: 473
Postby Hitec4you » Thu Dec 22, 2016 9:22 am
DWT77 wrote:
ELM wrote:Well your fenders won't fall now. That Por-15 is some awesome stuff. It's time to start making saw dust now. :)
Those suckers are definitely on there. I will have to head to Dallas to get some 5x10 sheets of plywood. Couldn't find any here in Oklahoma City. Will be doing that on Veterans day. So next weekend I will wire the jeep up for the 7 plug.
If you dont mind me asking.....Where did you get your Plywood from in Dallas? I work in Dallas and hopefully will be starting my TD next year.
Hitec4you
Postby DWT77 » Thu Dec 22, 2016 10:48 am
They are located in Fort Worth. They had everything I needed in stock. Walked in gave them my list. They put it all together, bound it, and loaded it on my trailer with a fork lift. Only took about 30 minutes.
https://www.plywoodcompany.com/MainSite ... /home.aspx
DWT77
Images: 473
Postby swoody126 » Thu Dec 22, 2016 11:03 am
NICE FOLKS to deal with!
just east of I-35w inside loop 820 north of down town
they also carry a lot of specialty lumber like mahogany and such...
they have a huge whse and will let you in to see their stuff
GOOD LUCK W/ YOUR PROJECT
sw
swoody126
Postby dshawster » Wed Feb 08, 2017 10:43 pm
The trailer looks really nice, what are the extra receivers for on the the front? If the rest of the project looks like the trailer its going to look awesome!
dshawster
Postby DWT77 » Thu Feb 09, 2017 10:30 am
dshawster wrote:The trailer looks really nice, what are the extra receivers for on the the front? If the rest of the project looks like the trailer its going to look awesome!
I put those there for a detachable Climateright Air Conditioning mount or a solar panel/pole mount (I don't want to mount my panels on the roof). Just thought it was something I would try. If I don't like how that works out I can either leave them there or get a grinder and cut them off. Figured it was best to put them on while I was building the trailer.
I am actually debating getting the flexible solar panels and storing them on the interior on my galley hatch.
DWT77
Images: 473
Postby dshawster » Thu Feb 09, 2017 2:34 pm
Cool, you could always find other uses for those it doesn't hurt to leave them there.
dshawster
Postby DWT77 » Wed Feb 22, 2017 6:03 pm
Got a little work done over the past 2 weekends. Got my template made. Exterior wall and middle walls cut out.
DWT77
Images: 473
Middle wall cut out
DWT77
Images: 473
Postby DWT77 » Sun Feb 26, 2017 11:25 pm
I decided to start a youtube series of my build as well. So if you see a better way to do something or have a question let me know. Experience/knowledge is always helpful.
https://www.youtube.com/watch?v=4t0oMyHbYaQ&t=2s
DWT77
Images: 473
Postby DWT77 » Sat Mar 11, 2017 9:55 pm
I have gotten most of the middle wall cut out. I will cut out the hatch tomorrow.
I also did a few test stains on my Russian Birch.
Top Left = Polycrylic
Bottom Left = Golden Pecan
Top Right = Pickled Oak
Bottom Right = Natural
DWT77
Images: 473
