Fred Trout wrote:[Mod - this needs to be a sticky thread, please ! ]
GPW wrote:http://www.charlesriverrc.org/articles/tools/joedydruliafoamcutterps.htm .... another alternative
ghcoe wrote:How much wire did you have between the clamps? I find around 3 feet to be ideal with my charger. Not sure if a shorter distance may cause a problem or not.
GPW wrote:We tried all kinds of wire over the years and the most durable so far is solid wire Fishing leader ( stainless steel) ... outlasted everything , even the expensive nichrome ...
GPW wrote:RT , the SS leader material came in a small package a few feet long , enough for a couple runs on my HW bow ... After breaking several other types of wire ( including Nichrome) One piece of the SS leader cut all the foam slabs for the FoamStream ... Variac as power supply ...
For cutting channels , we’ve used common Music wire set into wooden blocks , which worked fine with the Variac able to dial in the proper voltage ...
