That thing looks SO COOL!!!! If one was to say.... chose to not clear coat it, and i stead make it look like a flying saucer.... just sayin...
Alan_H wrote:Did you get the galley package to go with your CLC Teardrop?
aggie79 wrote::thumbsup: Very nice - as usual!
What are your thoughts on the NT aluminum trailer?
AzAv8r wrote:Interesting (and very efficient) battery mount, if I interpret correctly. The salient points of my understanding are:
- battery carried on beefy aluminum angles
- allthread cross-ties clamp the angles against the battery
- allthread hangers clamp the battery against the underside of the trailer floor
- the allthread hangers attach to T-nuts (?) installed on the floor from inside the trailer
- the battery is positioned in the center of the trailer laterally, and just behind the axle
- the battery is oriented on it's nominal "side", such that the terminals are on the vertical battery face towards the back of the trailer, close to the floor
- No extra material is used for the battery mount beyond the angles, the allthread, the T-Nuts (or alternate), and the battery itself.
Is this a correct interpretation? What size allthread? Maybe #10 for the cross-ties and 1/4" for the hangers?
Thanks for sharing!
