McDave wrote:Well, you do want a clean surface to paint, so your gonna have to wash it anyways. Get a bucket and maybe 25% white vinegar/water, and maybe a scrub brush and just give it the once over. Rinse the roof and the whole trailer down. Let that baby dry while you get your poop in a group for the painting op. If you feel like you need to mask off, this would be the time. Stir up that paint, go to the liquor cabinet and get the bottle marked "jack Daniels", Put 2 oz. of Jack into a large glass of ice, add lemonade. ...and get to work.
McDave
featherliteCT1 wrote:Yesterday I noticed that I could see daylight coming through one of the seams where the exterior aluminum panel was riveted to the rear corner of the trailer, near the ramp door.
I went to bed stewing in my mind weather it was an isolated manufacturing mistake where someone forgot to caulk or use sealing tape or whether the entire trailer was built this way. If the latter, what kind of a piece of &^%$#@! did I buy?
If I had known this in advance of buying the trailer, I would not have bought it. I would have bought a trailer with glued on exterior panels.
Ron
featherliteCT1 wrote:10-4 on that conclusion .... here is the caulk I am using, inside and outside all the seams: TremPro® 644 RTV, a one-part, general purpose, acetoxy silicone sealant.
This is what my Featherlite dealer uses. I bought 3 tubes at the local RV center for $3.79 per tube. It applied nicely and dried to a very flexible consistency ... when dry, it also stuck to the aluminum quite well. We shall see how it holds up.
I have not used it on the outside yet as i am waiting for the manufacturer to call me back to confirm the acetoxy will not harm the exterior paint .
rebar wrote:featherliteCT1 wrote:10-4 on that conclusion .... here is the caulk I am using, inside and outside all the seams: TremPro 644 RTV, a one-part, general purpose, acetoxy silicone sealant.
After reading about the nasty properties of silicone caulk (wont stick to itself, and almost impossible to remove) all over the RV forums, I wont use silicone caulk on anything..
I want say never ever but I avoid it !
I like Lexel.
featherliteCT1 wrote:So, a grand total of $625 … so far, just to insulate.
[/quote]So, a grand total of $625 … so far, just to insulate. McDave
