Looking for an A/C door.
Postby Hit-n-Miss » Fri Aug 25, 2017 4:42 pm
Anyone have a sourest for weather tight lockable access doors? Going to do a thru wall ac. Thinking of having something like this made.
. Or may just use door/hatch and slide ac out. Anyone got a source? Varying sizes? Thanks.
Hit-n-Miss
Re: Looking for an A/C door.
Postby John61CT » Fri Aug 25, 2017 5:00 pm
I think just fixed install? I can't see what good the empty box inside does once unit slid outside, still takes up space.
Roof mounted much better but yes pricey.
Sent from my HUAWEI ALE-L04 using Tapatalk
John61CT
Postby Hit-n-Miss » Fri Aug 25, 2017 6:27 pm
John61CT wrote:I think just fixed install? I can't see what good the empty box inside does once unit slid outside, still takes up space.
. The idea in my picture it would not slide out and it would have clearance around it externally to draw air. I figured I would build a closet below and around it floor to ceiling.
Hit-n-Miss
Postby McDave » Fri Aug 25, 2017 7:41 pm
Hey Hit-n-miss,
Try these guys.
http://www.ebay.com/itm/Dometic-RV-Refr ... SwyQtViHbf
I got a refrig access door from them. The first one was damaged when it arrived, but they shipped a new one that day. Great service.
McDave
PS I still have the damaged door if anyone is interested. Mostly the aluminium frame that's damaged.
McDave
Images: 412
Postby Hit-n-Miss » Fri Aug 25, 2017 8:41 pm
McDave wrote:Hey Hit-n-miss,
Try these guys.
McDave
. Thanks mc Dave. Looks like it would work even if door shut.
Hit-n-Miss
Postby McDave » Sat Aug 26, 2017 2:00 am
Hey Hit-n-Miss,
Yes, I believe it worked and latched. This is a vented access door, so not really weather tight. Maybe weather resistant?
The biggest issue I had with the damage was that its the aluminium frame that needs to seal to the wall where you cut the hole for the A/C. If you took your time and straightened the frame, and built a 1" x? frame to screw to with some isobutyl tape should be fine. Hole size is 14" x 22" I believe. Let me know ..
McDave
McDave
Images: 412
Postby Hader » Sat Aug 26, 2017 5:50 am
Why not go through the floor?
Mine is working as it should be, and I never have to worry about the rain.
Hader
Images: 84
Postby NO David! » Sat Aug 26, 2017 9:08 am
NO David!
Images: 37
