GPW wrote:1. It doesn’t really NEED paint , but if you leave it bare it would look nice with some full strength poly as a “finish” ...
2. Probably ... depends on the glue ... GG would stick ... T2 , I don’t really know ... Time for a test sample ...
3. You let the thinner DRY thoroughly , it evaporates ( couple days ) ... I painted Latex ext. house paint on my Big TD after the mix ... no problems .... stuck just fine ...
When ever in doubt ... test first ...
GPW wrote:Dan , I’ve been a professional Artist for 47 years now and I Know paint .. It’s my Job !!!
was the latex paint water based or acrylic enamel? ( It’s the same thing , Latex/Acrylic is water based… not to be confused , ALKYD paint is solvent based) is there a need to prime before painting? ( Priming prepares the surface providing good adhesion and a uniform base color to paint over… I always prime first, and if you let it dry a bit , you can sand it smooth ) I had heard that latex paints don't stick well to oil based products. ( True !!! You can paint Oil paints over Acrylics , but never Acrylic over Oil paint ( It will peel off, won’t stick) , unless it’s completely dried, still , not recommended !!! With the mix , the Mineral Spirits is allowed to flash off /evaporate , and the poly once completely dry is plastic and seems not to mind whatever you put on it . That and there’s no Film formed when used as a waterproofer … on a regular poly finished surface you’d have to sand it to create some ”tooth” for the paint to adhere to ... ) Thanks ( you’re more than Welcome)
Dan , apologies if I appear to be “short” sometimes , but there's only so much information to building a Foamie , and we’ve repeated it so many times over and over now , we’re starting to sound like a broken record (a Parrot ) … Apparently just presenting the material to read is insufficient … It was always assumed ( and amply demonstrated) that the individual builder would “ know better” interject their own ideas and methods as they saw fit ( encouraged) … A Foamie is the “Thinking Man’s “ trailer …
The old Foamie motto : when in doubt , TEST it !!!
lthomas987 wrote:So, if I use the mix on some wood, do we think contact cement will still bond with it? I know we've talked about not sealing parts where we want to glue or paint for better bond, but contact cement is sort of a different animal. This is for a plywood surface that will end up having to live outdoors. And I'm going to glue a rubberized surface to the top it with contact cement.
GPW wrote:"but this is supposed to be the concise thread on waterproofing wood right? “
ER, Not really !!! We’re all Volunteers here … not scientists or Experts that one could hold accountable … ( why we recommend so much individual testing)
JMHO, putting all the waterproofing coats on at one time .. May ( or may not) be the best way … alla prima , yes, that will take some time to dry because the outer coats dry first, sealing off the surface , leaving the inner mix to remain wet longer … ( good or bad ? I dunno’ )
Old school , one would paint on one coat, let it dry , and repeat till sealed to satisfaction.
dancam wrote:lthomas987 wrote:So, if I use the mix on some wood, do we think contact cement will still bond with it? I know we've talked about not sealing parts where we want to glue or paint for better bond, but contact cement is sort of a different animal. This is for a plywood surface that will end up having to live outdoors. And I'm going to glue a rubberized surface to the top it with contact cement.
Wont the contact cement and rubber keep water from getting in? Using it on exposed surfaces sure, but im not sure why you want to use ut under contact cement and rubber.
Wont the contact cement and rubber keep water from getting in? Using it on exposed surfaces sure, but surely not sure why you want to use ut under contact cement and rubber.
