Is the “V” considered in the overall length?
Postby jay87lx » Sun Oct 22, 2017 8:18 pm
Is a v nose trailer usually measured from the tip of the V to the rear for overall length?
So a 7x16 is 16’ from the tip of the v to the rear?
jay87lx
Re: Is the “V” considered in the overall length?
Postby Dano-Mich » Sun Oct 22, 2017 9:33 pm
Depends on the manufacturer. Two examples - Legend calculates it so a 7x16 box with 3' v-nose is a 7x19. R&R does not count it. These are just two I have looked at recently. Make sure and double-check the specs!
Dano-Mich
Images: 27
Postby Viper_Twig » Mon Oct 23, 2017 12:07 am
Measure or ask. Mine is a 6x12 not including the shallow v nose
Cheers
Viper_Twig
Postby CoventryKid » Mon Oct 23, 2017 12:41 am
My 7x16 NEO v-nose is 16' on the box. The v-nose adds about 2' on top of that. With the tongue, total length is 20' from hitch to rear.
Hope this helps.
Doug
Vancouver Island, BC
GMC Savana Explorer Limited SE hightop conversion van
NEO NAVR 7x16 V-nose aluminum trailer now a comfortable travel trailer
Build: http://www.tusker-international.com/1-trlr-build.html
CoventryKid
Images: 130
Postby onehoser » Mon Oct 23, 2017 9:32 am
my 5x8 titan stet v-nose is 5x8 plus 2' for the v
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby flboy » Mon Oct 23, 2017 10:07 am
My Lark was stated as 18'*7' plus 2ft V nose. So in this case, it is in addition.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Gonefishin » Mon Oct 23, 2017 10:31 am
My Haulmark 6X12 does not include the V, so its really about a 6X14, or something.
Gonefishin
Images: 119
Postby Padilen » Mon Oct 23, 2017 1:59 pm
I've mentioned that there isn't any set standard for any measurements. Including the 6" raised roof. ___+6" still gives you 6" added. Make sure your getting exact measurements.
Padilen
Postby m.colley » Mon Oct 23, 2017 6:55 pm
My 7X16 doesn't include the V-nose. Its a 16ft box plus 2ft V-nose.
Martin
m.colley
Images: 83
Postby jay87lx » Wed Oct 25, 2017 6:42 pm
Thanks folks!!!
Shopping for a trailer can get a bit stressfull. Frame size, length, cargo or barn doors, smooth sides, aluminum or galvanized roof, ceiling, walls etc 16 or 24 oc.
I am trying to avoid ordering what I want
jay87lx
Postby m.colley » Thu Oct 26, 2017 5:25 pm
jay87lx wrote:Thanks folks!!!
Take your time deciding, you'll understand more once you design your layout. Walk around in a few cargo trailers if you have a dealer close by just to get some ideas of how things will affect your decisions.
Here's an example. I have a stocking dealer close by. I thought a 6"3" ceiling would be tall enough. After walking thru a couple of trailers I knew I needed at least 6 more inches of height. At the same time I was able to look at the differences between three different builders/manufacturers, and what each considered a "standard item vs optional". It also allowed be to get a sales sheet on each builder with a list of some of the more common "optional upgrades".
I added 6" in height, spare tire, extended tongue, window, upsized entrance door, spare tire mount, upgraded rear ramp, etc. I was able to see a similar equipped unit on the dealers lot..
Martin
m.colley
Images: 83
Postby DIY_Stu » Wed Nov 01, 2017 4:13 pm
I do not believe any manufacturers include the V nose into the measurement. It's usually just the Square of the box. Depending on manufacturer the V can be 2-4 feet
DIY_Stu
Postby Dano-Mich » Wed Nov 01, 2017 8:43 pm
DIY_Stu wrote:I do not believe any manufacturers include the V nose into the measurement. It's usually just the Square of the box. Depending on manufacturer the V can be 2-4 feet
Legend does, but is the only one I've come across after checking quite a few. Not sure why they want to be different. Its misleading to include that v-nose length in their model numbers.
http://www.legendmfginc.com/
Dano-Mich
Images: 27
Postby Padilen » Thu Nov 02, 2017 7:13 am
And Beck's(MI dealer) does for theirs, which includes Legend. When I was looking, some other dealers gave overall legnth, too. But may have been competing with Beck's measurements.
Padilen
