The 3M respirators are best in my experience. Might as well go for the charcoal filters, too, especially since you are using epoxy. They don't always say charcoal on them, but they will be the "contractor" grade for use with chemicals (as apposed to the "homeowner" grade that is usually just for dust). Keep the filters in a zip lock bag when not in use so that the charcoal doesn't just soak up everything all of the time.
Lou.Catozzi wrote:After two months I've finally gotten a little time in on Learning Curve today. Part of the delay is that I'm building in an un-air-conditioned garage in Texas.
aggie79 wrote:Lou.Catozzi wrote:After two months I've finally gotten a little time in on Learning Curve today. Part of the delay is that I'm building in an un-air-conditioned garage in Texas.
I feel your pain on the heat! Here's a pic of the temperature at 8:00 p.m. in Watauga (NE Fort Worth) on the day I was applying the poly to my teardrop's cabinets:
The older I get, the more the temperature in Texas seems to be too hot or too cold. I wish we had longer spring and fall seasons.
There wasn't much room to spare, so we were always moving things around for the best access. My trailer was the easiest to move, so it moved the most; I kept my parts & supplies inside it, for that reason.
Lou.Catozzi wrote:Earlier this week I finished putting 3 coats of polyurethane on the cabin bottom so today I decided to apply the asphalt roof and foundation coating that should be the final waterproofing layer. The gallon can said that it would cover 50 sq feet so I thought "perfect!". They recommended a roller for applying it but I decided to use an old 4" paint brush I had laying around the garage. It went on thick and glossy but as I finished coating half the floor bottom I had no where near gone thru half of the can. By the time I finished one coat it was apparent that I had enough for at least a second coat, and maybe a third! I managed to coat the entire floor in about a half an hour without getting any of the asphalt on myself, my clothes, the rest of the trailer, or the garage floor.
I'll let it dry/cure for a day or two and see how hard it sets up. I am anxious to flip it over and get it bolted down the trailer frame. Total cure time is 30 days! I am NOT waiting that long!
