Good to hear you’re getting back in the swing of things KC!
I'm glad tho hear about progress! I'm starting to pick up momentum! Hope you can too! Btw... you wouldn't believe the temps I've mixed epoxy in! Extremes in both directions!KCStudly wrote:I did a little more on the fridge lid on Friday, but the temps here are still too cold for epoxy; it was about 45 deg F all day. (We had a light dusting of snow yesterday and are expecting more again tonight.)
So I just used TB2 to laminate the foam down to the panel and get the rest of the rim frame attached to the other two corners. Took one picture of gravity and spring clamps hiding most of the part; which didn't seem to be worth downloading from the balky camera. (Maybe next time I will see how my new action camera does for still shots?)
I waffled around a bit trying to decide what I could do while the glue dried, but being as it was too cold for epoxy, and I wanted to give the foam-to-wood glue-up plenty of time (especially in the cold), I didn't get much further.
I surveyed the aft street side of the camper again from my little staging (camper box still laying on the curb side) and decided to try and fill a relatively large area that feels like an air bubble. It's about the diameter of a coffee cup that pushes down and springs back under sanding pressure. Drilled two small holes the size of my syringe tip, one fill and one vent, but didn't mix any epoxy yet.
Need some consistently warmer weather, above 50 deg F, to get back into epoxy work.
I'm in Idaho it's actually nice here. About 50 high today.KCStudly wrote:Thanks guys. Sort of like the groundhog, Punxsutawney Phil, I came out of my hiding spot, got pummeled by snow, and am holed up again... at least until the weather breaks again. We will see what the weekend brings. (I suppose I should check the forecast. )
Was in Boise today closer to your end target. Beautiful country and first time ever in Idaho.KCStudly wrote:Thanks for the enthusiastic support, Ned!
I made the trek to the shop today hoping to be able to do a fiber filled repair on that miss-cut corner, and perhaps bevel and fill the bottom edges; but the fairing coat was still tacky. Too cold, didn't cure all the way yet. On some areas of the seams between the frame and foam, and the foam butt joints the filler had sunk down in leaving low spots and/or voids; so I decided to try another fairing coat, betting that the gumminess was still active w/o an amine blush to interfere.
Hell, for the amount of time and material I have in this so far, I probably should have taken Larry's advice and just bought a new replacement.
Anyway, I mixed another small batch of fairing filler and spread it on; this time leaving it in the cup a bit longer until I felt a little bit of warmth, and then, once spread, I went over it good with a hair dryer set on high heat (milder than a heat gun). This brought some bubbles up from some of the seams, which I popped using a bamboo skewer, then refilled.
I suppose I should have switched over to the fast hardener yesterday, but I hadn't, so used more of the slow again today (West says not to mix in process).
I suppose it will kick... eventually. Hopefully the hair dryer did the trick.
Users browsing this forum: Google [Bot] and 0 guests
