- Thanks, Don. Good job. Apparently the spline doesn't have a groove in it to match the pinch bolt? Can you give us an exact measurement from the hub face to the back of the swing arm?
![peace :peace:](./images/smilies/peace.gif)
d-hartman wrote:Guys
I only assumed that it being on the spline it could be tweaked.There is a saying about that. But if you look at the photo it does look as if the bold would have to be in a groove in the shaft as Madjack mentioned.
I can get some more detailed dimensions on sunday afternoon.
Did you look at my Pics?
Hope I did not confuse anyone.
Don
d-hartman wrote:I got a 2000# with frame outside dimensions of 60" and a hub face to hub face dimension of 73-1/2 .I bought 2 15" wheels with 0 offset and have also purchesed two p205-75-r15 tires.
waxtracker wrote:Going by what what I see on this last drawing, if you used a 10" fender, you would have to probably use a half-inch or so spacer to get enough clearance? What would any of you suggest for clearance from the outside of the tire to the fender outside edge or should you just center the fender and measure for spacers?
Kerry
Groves, TX
