6x12 Tiny Home Build - briansroadtrip.com
Postby btafoya » Thu Mar 15, 2018 12:18 pm
I have begun my buildout for my stealthy tiny home/camper conversion with a new Covered Wagon V-Node trailer.
Currently, I working on completing the insulation, polystyrene form with expandable spray foam for any cracks.
By next week I should be well into the cabinet framing including the install of a GE 5,000 btu Utility Room/Window AC Unit. My plan is to vent out the side, but take fresh intake air from the bottom, building a plenum down to the floor.
Any suggestions as to which vent grills I could use. especially ones with some sort of mesh to keep critters out?
Thanks!
Brian T.
Building away! 6 x 12 Tiny Home - My Build http://tnttt.com/viewtopic.php?f=42&t=70120
My travel site: https://briansroadtrip.com
btafoya
Re: 6x12 Tiny Home Build - briansroadtrip.com
Postby McDave » Thu Mar 15, 2018 6:47 pm
Hello btafoya,
Congratulations on your new trailer and the start of your stealth conversion. Is that a 6 x 12? You are off to a good start with the insulation, it helps a lot with heat/cooling and noise. When it comes to Air conditioning configurations, they are as varied as the styles of trailer and uses. Personal preference as to type and style. In general if using window AC higher placement is more efficient. The only thing I can think to use to keep critters out would be metal window screen. May want to use a louvered grill with screen behind it and have the louvers facing rear so as not to pick up water/dirt if placed underneath. If you search this forum you will find many, many AC installs. You may want to start by reading the installation instructions for the unit you intend to use.
Good Luck,
McDave
McDave
Images: 412
Postby Iconfabul8 » Thu Mar 15, 2018 11:31 pm
Welcome to the madness! :? Looking forward to your build.
If you want super stealth you need to check out Hader's AC install. It's pretty cool (Pun intended.)
Iconfabul8
Images: 14
Postby btafoya » Fri Mar 16, 2018 12:15 am
That is exactly what I was searching for! I saw a YouTube video on someone installing the window AC unit a-la-stealth but could not find it when I went back to look. Thank you very much!
Brian T.
btafoya
Postby btafoya » Fri Mar 16, 2018 12:26 am
Thanks Dave!
McDave wrote:Hello btafoya,
Good Luck,
McDave
Brian T.
btafoya
Postby sodatrain » Sat Mar 17, 2018 8:36 pm
Hey! Looking good. Checking out your website too! Looking forward to watching your build.
My 7x7x14 Tandem Axel build thread: viewtopic.php?f=42&t=69731
sodatrain
Images: 19
Postby Hader » Sun Mar 25, 2018 11:38 am
Any updates?
Hader
Images: 84
Postby Riyan17 » Sat Mar 02, 2024 10:20 am
The 6x12 Tiny Home Build featured on briansroadtrip.com is a masterpiece of compact living. With clever design and efficient use of space, this tiny home offers comfort and functionality in a small footprint. From its cozy interior to its innovative storage solutions, every detail has been carefully crafted to maximize comfort and utility. Explore this inspiring project for ideas on how to create your own perfect tiny oasis.
story saver
Riyan17
Users browsing this forum: Bing [Bot] and 8 guests
