Maybe running ac off em?tony.latham wrote:Your wheels are turning.
I think your weight estimate is probably close. I do wonder what you're going to power with those two batteries though. I would think you could shave that down to one 12V. Having said that, It's obvious you're doing your research so perhaps you've figured out you'll need that many amps.
dancam wrote:Maybe running ac off em?tony.latham wrote:Your wheels are turning.
Or a fan all night?
Its pretty unbelievable how big of a battery you need just to run a fan for a few hours...
John61CT wrote:Trailer brakes for sure
Keep the tongue weight to 10%, unless you're really diligent about the rear GAWR, do you need the rear seats? Etc
Easy in the mountains, tranny temp gauge and a cooler.
Tom&Shelly wrote: Just yesterday we tried to back our HF utility trailer loaded with junk, up our (uphill) driveway, and Shelly's Jeep complained about overheating transmission fluid. First time we'd seen that. She researched it last night, and now we plan to upgrade or add a 2nd cooler. A gauge is a very good idea.
John61CT wrote:Well my point is, to the extent you weigh down your back axle, the less capacity you have for towing (safely)
