What are you going to use for a hinge on your box?
tony.latham wrote:What are you going to use for a hinge on your box?
DWT77 wrote:tony.latham wrote:What are you going to use for a hinge on your box?
I am going to use a hurricane hinge. I got the idea of this box from the below build. I thought it was a really nice build
viewtopic.php?p=1047445#p1047445
tony.latham wrote:DWT77 wrote:tony.latham wrote:What are you going to use for a hinge on your box?
I used one to replace my failed plastic hinge on my tongue box. Much smaller than most hatch hurricanes.
DWT77 wrote:Maybe a clearer question is
The center pin on 7 pin connector on the vehicle side is for reverse lights.
To the left is the Jeep wiring colors. There isn’t a wire for reverse lights. Only Tail, Brake, Turn and ground.
So in order for my reverse lights to work on the trailer is all I need to do is splice into the reverse lights of the Jeep?
I think it might be the single use bulb labeled "brown" but Right turn and Brakes are labeled "brown" as well
clamlamp wrote:Beautiful work! Been following for a while now. Bravo
Sent from my ONEPLUS A3000 using Tapatalk
