SoapCreek Adventure Trailer
Re: SoapCreek Adventure Trailer
Postby tony.latham » Sat May 12, 2018 9:27 pm
Currently tongue is just bolted in.
On my next build, I'm toying with a removable tongue. It would be impossible for a thief to tow.
:thinking:
T
Postby soapcreek » Sat May 19, 2018 4:36 pm
And now I have walls...
soapcreek
Postby georgecardonajr » Sat May 19, 2018 9:14 pm
soapcreek wrote:And now I have walls...
Nice design!
georgecardonajr
Postby soapcreek » Wed May 23, 2018 11:09 pm
Continuing to make progress...
soapcreek
Postby soapcreek » Mon May 28, 2018 9:41 am
Getting ready to skin the outside.
soapcreek
Postby Sparksalot » Mon May 28, 2018 10:36 am
Nicely done with the underfloor storage.
Sparksalot
Images: 682
Postby soapcreek » Mon May 28, 2018 10:26 pm
Sparksalot wrote:Nicely done with the underfloor storage.
Thanks, pulling inspiration from a lot of the great builds on here.
soapcreek
Postby soapcreek » Mon May 28, 2018 10:27 pm
Framed out the back hatch and taillights between the activities of the day. Didn’t get around to skinning the front and top yet. Plan is to camp a couple times before deciding what we want for galley setup. Unfortunately I am not going to make my original goal date but should have it usable in another couple weeks. That is if I can quit thinking of things to add to the short list.
soapcreek
Postby soapcreek » Fri Jun 15, 2018 10:05 pm
Finding it difficult to get out of vacation mode and get back to work on the trailer. I did finish the hatch door this evening. Started to round over the edges also.
soapcreek
Postby jschrotenboer » Tue Jun 19, 2018 11:28 am
Nice work! I've been impressed and following your build. Slowly trailing far behind through a similar build. :)
Sent from my SM-N950U using Tapatalk
jschrotenboer
Postby soapcreek » Wed Jun 20, 2018 10:44 pm
jschrotenboer wrote:Nice work! I've been impressed and following your build. Slowly trailing far behind through a similar build. :)
Thank you. I’m still hoping to have it to paint by the end of the month. One thing I wish I could do over is the outside skin. I should have moved the first piece higher on the front so it didn’t break on the curve. Currently sanding and applying a thin layer of filler to get a smooth curve. Ultimately it will get covered so I think it will be ok but if I had it to do over I would do it differently.
soapcreek
Postby soapcreek » Sat Jun 30, 2018 12:04 am
Haven’t really made any progress this week. Just pulled it outside to get ready for rounding over edges and sanding the wood filler over screws and knots tomorrow. It doesn’t look quite so big outside the shop on its own wheels.
soapcreek
Postby Sparksalot » Sat Jun 30, 2018 2:02 pm
I'm digging your running boards. Are you going to finish it as a woody?
Sparksalot
Images: 682
Postby soapcreek » Sat Jun 30, 2018 2:29 pm
Sparksalot wrote:I'm digging your running boards. Are you going to finish it as a woody?
Thank you. Going with spray on bed liner (Linex). Going to color match my truck.
soapcreek
Postby soapcreek » Sun Jul 01, 2018 1:08 pm
Successfully removed the cabin from the trailer, rolled it on all four sides to round over corners/sand and put it back onto the trailer without it breaking into pieces. I’m calling that a win. No pictures to prove it happened though.
soapcreek
