June 14 ,2018
Slow progress, but progress. Installed another light under the counter top. I am going to have a swing out cabinet and this light should help light some outside. Installed new axle , hubs and wheels. Northern tool has a direct bolt on 2k replacement axle for anyone that want to go 5ft wide on the HF 4ft trailers.
https://www.northerntool.com/shop/tools ... _200648951. This will leave 1.5 inches of clearance. You will need new 4" by 1.5" ubolts. The originals are just too short . I put my wall on top of my floor though and have 58" inside. If you put wall on the side of floor, the 71 inch hub face axle will not work. After putting these tires on, I cant believe, that I put that many miles on the little tire.
