Wall Framing Size Questions for Strength
Postby Patrick Star » Fri Sep 14, 2018 10:53 am
Hi, my plans for my Caveman build calls for 1.5x.75 wall studs and framing... does this seem a little thin? I know the plans were drawn to save weight, but would like something a little stronger, as where I camp routinely sees 25-35 mph winds (beach camping)
I was considering using 2x4's in the wall instead of 1x2's
I basically need to find strength.
Building my camper in a 1992 Coleman Chesapeake pop up trailer. 300 bucks so far. And that includes the Tax, Tag, and title!!! So excited
Harbor Freight has saw horses on sale and picking some up today
Sent from my SM-N950U using Tapatalk
Patrick Star
Re: Wall Framing Size Questions for Strength
Postby Ottsville » Fri Sep 14, 2018 11:03 am
Let's apply a little critical thinking here... if you are using plans that someone designed for pulling down the road...don't you think the wind load on the road is probably more than the winds you will get while parked?
Ottsville
Postby lfhoward » Fri Sep 14, 2018 11:09 am
You’ll most likely be fine with 1x2’s. If you’re worried about strength then go up to 1x3’s for major support structures, and 2x2’s for roof crossbeams. 2x4’s is going to be way heavy for very little gain. You’d be amazed how strong the structure is once the plywood walls are glued and screwed to the 1x’s. It’s not going to move.
lfhoward
Postby KTM_Guy » Fri Sep 14, 2018 2:22 pm
1X2’s are probably fine. The hard part is to find good ones. The ones at Home Depot and Lowes will be junk. Buy 1X6 or 1X8 and rip them down. Or find a source for Popular, or another hard wood. You can buy #1 common red oak or even #2 common at reasonable prices.
KTM_Guy
Images: 193
Postby Patrick Star » Fri Sep 14, 2018 2:58 pm
I actually Laughed out Loud when I forgot the whole wind going down the road, that's great to know.
Thanks for the advice on upscaling my build!! I think the 2x2 and the 1x3 will be my choice.
I have a roof top AC I'll be setting on there too, I'll start a build thread once I clean out my work space
Patrick Star
Postby QueticoBill » Fri Sep 14, 2018 6:27 pm
The wall strength comes from the skins, not the framimg.
QB
QueticoBill
Images: 22
Postby lfhoward » Fri Sep 14, 2018 6:39 pm
KTM_Guy wrote:1X2’s are probably fine. The hard part is to find good ones. The ones at Home Depot and Lowes will be junk. Buy 1X6 or 1X8 and rip them down. Or find a source for Popular, or another hard wood. You can buy #1 common red oak or even #2 common at reasonable prices.
I paid extra to get the “select” pine for my 1x2’s & 3’s at HD. I was choosy and made sure they were straight and the grain was nice as I took them off the rack. They are 2x-3x as expensive as the “common board” pine but it’s worth it for durability. The common stuff was lighter (wider grain), had knots and was twisty, whereas the select was heavier, straighter, better wood. The select also held together nicely when drilled for pocket holes.
lfhoward
Postby tony.latham » Fri Sep 14, 2018 7:31 pm
I used 1-inch pine with my first teardrop. I found it labor intensive. I much prefer 3/4" plywood. Much quicker with more flexibility to reinforce where needed or lighten up where possible.
I can gang-cut two plywood frames and be ready for the next step in a couple of hours.
Postby lfhoward » Fri Sep 14, 2018 7:50 pm
Very good point, Tony. My trailer is boxy and only has 90° or 45° angles on it. The stick frame would be a pain to build for a curved teardrop profile.
lfhoward
Postby noseoil » Wed Sep 19, 2018 7:05 am
The 3/4" skeletonized plywood wall is what I did as well & it's fine. I cut out a bit more of the wood than Tony did, but it's still plenty strong & has stood up to everything we have done so far. We used 1/8" baltic birch inner & outer walls, with 3/4" foam insulation in the voids. As was mentioned, the skins are what really strengthen this type of build. The 3/4" material serves to keep the skins separated so when they're glued in place, it acts like a "trussed" type of structure & the layers of skin & frame become a solid panel which is light & very strong.
Don't use 2x4's unless you have a semi truck for a tow vehicle, it's a waste of material, weight, time & money!
137818
137905
noseoil
Images: 669
Postby GPW » Wed Sep 19, 2018 7:55 am
Airplane style framing . Light, Strong … And airplanes fly at hundreds of MPH … ;)
Skinned Beaded styrofoam walls @ 3.5” Thick with 18oz. outer Canvas skin and chipboard inner skin … 5 years and counting now , living outside all the time in our Rainy weather … :thumbsup:
Postby Patrick Star » Tue Oct 02, 2018 11:34 pm
I totally understand it now.. Thank you for your patience. On the roof I'll use the 2x2's for the spars under the roof top AC, it's pretty heavy. and the framing under it 1x3, hardwood. This camper will literally be going down 100s of miles of beach on the Natl Seashore, but the torsion box strength is clear
Patrick Star
Postby Tigris99 » Wed Oct 03, 2018 11:12 pm
1x2 is more than enough since your skinning the inside and outside with some form of plywood. My previous build I filled all the wall spaces with XPS foam, only had 3/16 luan skin. Held up doing 80mph down the highway and didnt phase it.
Roof I used same except 2x2 spares, only because we get nasty storms that knock down limbs all the time. Camper took a few limp hits over the year, dealt with gusts of 70mph from storms here and 0 issues.
Your WAY over thinking this. Beach winds are nothing. Dont go crazy with wood, just use XPS foam so you stay light but creates a solid sandwiched wall. My previous build I never had a single concern with and this build I know more than during that build so I'll be lighter and as strong if not stronger.
Just a heads up, do some research on how planes are built, especially ones of old. Those dealt with far more tha your camper will ever deal with short of a hurricane and they were built scaringly flimsy
Sent from my SM-G950U using Tapatalk
Tigris99
