Chesapeake Light Craft Teardrop Trailer
Re: Chesapeake Light Craft Teardrop Trailer
Postby djdawg » Fri Aug 31, 2018 10:32 am
Thanks Fritz....I'm over there too. (teardropkevin)
Speaking of sale! Everything is on sale and the base kit is $110 off until Tuesday.
Kevin
Bellingham, WA
djdawg
Postby FinsUp » Mon Oct 22, 2018 1:29 pm
I am pretty sure I camped next to you at Wilson lake last year for the Mountain bike race. I was in the 100 series land cruiser. You have a beautiful trailer and I told my wife about it when I got home. Great job!
As a dreamer of dreams and a travelin' man,
I have chalked up many a mile.
Read dozens of books about heroes and crooks,
And I've learned much from both of their styles.
FinsUp
Postby friz » Sat Oct 27, 2018 11:16 am
FinsUp wrote:I am pretty sure I camped next to you at Wilson lake last year for the Mountain bike race. I was in the 100 series land cruiser. You have a beautiful trailer and I told my wife about it when I got home. Great job!
Thanks, I'm sure that was me. I worked for the bike shop sponsoring the event that year.
Sent from my SM-G930V using Tapatalk
The "Sin Bin"
150133
friz
Postby friz » Sat Sep 07, 2019 3:13 pm
Update: over winter I noticed that the corners of the stock fenders were cracking out. Also, even though I had removed leaves from the springs, they were still a little stiff. I bought some springs rated under a 1000 lbs and some curved aluminum fenders. I have been out a couple times this season and found the upgrades to be worth it. Next winter will probably be sanding the finish and applying a couple more coats of varnish. I have quite a few dings and scratches that need to be covered and protected. I show this little camper no mercy.
The "Sin Bin"
150133
friz
Postby capnTelescope » Mon Sep 09, 2019 9:46 pm
Good move on the fenders, Friz. Me and others I've met have all had sandblasted fenders to deal with. I think your diamond plate is the best solution. :thumbsup:
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby friz » Mon Sep 09, 2019 11:03 pm
capnTelescope wrote:Good move on the fenders, Friz. Me and others I've met have all had sandblasted fenders to deal with. I think your diamond plate is the best solution.
More function over fashion. My flip flops live on the fenders while I sleep. The diamond plate keeps them from sliding off.
The "Sin Bin"
150133
friz
Postby friz » Sat Apr 10, 2021 11:12 am
Still truckin'. 4 yrs on.Image
Sent from my SM-G965U using Tapatalk
The "Sin Bin"
150133
friz
Postby Juneaudave » Sat Apr 10, 2021 11:38 am
Really looks good!
Juneaudave
Images: 380
Postby Ottsville » Sat Apr 10, 2021 7:27 pm
friz wrote:Still truckin'. 4 yrs on.Image
And still looking great. Where is this photo taken? I feel like I know that place.
Ottsville
Postby friz » Sun Apr 11, 2021 6:41 am
Blowing springs Park. Arkansas.
The "Sin Bin"
150133
friz
Postby friz » Sat Apr 17, 2021 10:51 am
https://www.amazon.com/dp/B07RDHP3KP/ref=cm_sw_r_cp_apa_glt_fabc_BGN7BZ2Z296P62WY40YZ
I am going to try some of these around the camper for convenience and security.
The "Sin Bin"
150133
friz
Postby friz » Sun May 09, 2021 11:40 am
friz wrote:https://www.amazon.com/dp/B07RDHP3KP/ref=cm_sw_r_cp_apa_glt_fabc_BGN7BZ2Z296P62WY40YZ
These were a bust. In testing, only 2 of the 5 worked as intended. The other 3 cycled on and off continuously. Also no apparent waterproofing. I returned them.
The "Sin Bin"
150133
friz
Postby whiteryanc » Sun Dec 19, 2021 10:40 am
Love this project, so well done! I know you've commented on some aluminum trailer threads and it looks like this trailer is holding up just fine!
Do you do any regular maintenance/bolt checks and do you have to do much adjustment ever? I have a similar powered vehicle (Subaru Crosstrek) and have been looking at building an ultralight trailer but have no welding/fab skills so the bolt together aluminum trailers are particularly interesting.
Thanks for all the great documentation and images!
whiteryanc
Postby friz » Sun Dec 19, 2021 11:48 am
whiteryanc wrote:Love this project, so well done! I know you've commented on some aluminum trailer threads and it looks like this trailer is holding up just fine!
The trailer is fine as long as you keep the weight down. The only must do is packing the bearings with quality grease and properly adjusting the axle nut as you would for any tapered bearing. I jack up either side on occasion and check the play in the hub by moving the wheel laterally and checking for end play. You want just a little to allow for expansion from the heat from friction. I also touch the hubs when I stop for gas to check for heat. These hubs have always run cool.
After living with this camper, I can not imagine doing it any different. We added plastic boats to rig this year. Great addition! Its sitting in the garage, locked and loaded for next spring. Can't wait!
The "Sin Bin"
150133
friz
Postby pchast » Sun Dec 19, 2021 10:43 pm
I'm always impressed with your rig.... :thumbsup:
An Aside, I've been changing the CVT fluid In my outback every 25000. :thinking:
Mine gets brown and the coolant temperature raises by 10deg in that time.
Changing the fluid reduces coolant temp for several thousand miles before
it starts to creep up.
pchast
Images: 97
