Intellipower 4045 versions
Anything electric, AC or DC
Postby bushido41 » Fri Nov 23, 2018 1:06 pm
Hello Everyone,
I have an older intellipower PD4045 , that has no way to connect a DC disconnect switch. Looks like the new ones have a way to add a disconnect switch. What Im planning to do is to splice a longer piece of number 8 or10 wire to the DC disconnect switch, and the other side of the switch to the fuse switch area of the intelli power. I was wondering if anyone has done that previously, and any words of caution.
New intelli4045.jpg (213.89 KiB) Viewed 2063 times
This is my new trailer that I have been working on for a few months. Is a Weeroll Silver Cloud Xtreme.
I will be creating a thread of my build soon.
Thank you for the comments.
Ed
K4BQN
bushido41
Images: 57
Re: Intellipower 4045 versions
Postby GuitarPhotog » Fri Nov 23, 2018 3:39 pm
Why do you not want to just put the switch in series with the + wire from the battery to the Converter?
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby bushido41 » Fri Nov 23, 2018 7:38 pm
Hello Guitar,
The main reason, is that I want to measure the load of all my 12 v devices at all times, and also be able to disable the 12 volt flow to my device. If I connect the switch to the battery, I can only measure the load or disconnect if IM using the battery , since the 4045 is converting 125 to 12 volts, and providing the voltage to the fuse panel within the 4045.
Ed
K4BQN
bushido41
Images: 57
Postby GuitarPhotog » Fri Nov 23, 2018 8:01 pm
The 12V disconnect on the 4045 completely disables the 12V circuits, including the converter. It's not just a battery disconnect.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby bushido41 » Fri Nov 23, 2018 8:15 pm
Guitar,
Indeed, that is exactly what I want to do.
Ed
K4BQN
bushido41
Images: 57
Postby bushido41 » Sun Nov 25, 2018 1:58 pm
Completed the wiring of the light switches, and AC, and DC meters, plus the DC Disconnect switch.
Ed
K4BQN
bushido41
Images: 57
Return to Electrical Secrets
