Check out the Paddywagon!
Postby 2bits » Fri Nov 23, 2018 10:44 pm
I have been wanting a commercial camper top for years because of the doors in back and I started with wanting to do that waaaay back in the beginning but they were too expensive so then moved on to building a truck camper and then I found teardrops and it was all over haha. I am building a standy right now but have missed a few gatherings this season and needed an “insta-Camper” badly. These are usually white so I couldn't pass up this black one at $300. I think it looks pretty cool and the doors on the back are the key to this working comfortably as a camper until my standy is done. I am always buying rebuilder trailers so this will continue to earn it’s keep for when I go to pick one up that is far away and don't want to drive home the same day.
It has an aluminum rack that I removed and will paint black to match and reinstall so I can still haul lumber and plywood. So far I have cleaned up and added some vinyl peel and stick wall paper to the outside cabinets and done the same to the back side of the cabinets inside the camper. I just put down a sheet of foam insulation and a full size memory foam mattress and went around the edge with some brand new shag carpet cut offs that I had laying around. (This is what we mean by I will use that someday!!) I also removed the expanded metal window security stuff and it will not be going back on and added curtains in front and back. The windows let in alot of light and looks great while sitting in bed.
Future plans are to add an 110 inlet for campgrounds and a couple of outlets, a roof vent, and also cut into the backs of the cabinets and make doors so I can access them in and outside of the camper. On one side, I am going to add a side window that I have which is the same style as the back windows. Lastly I am going to insulate and finish out the ceiling and make some door panels. I already have a rear rack that I can strap down my cooler on the left and it will make for an entry “porch” on the right of it.
Thomas
2bits
2bit Member
Re: Check out the Paddywagon!
Postby 2bits » Fri Nov 23, 2018 10:46 pm
Nice view from inside and a before and after pic of the side cabinets. These will act as my galley :D
Thomas
2bits
2bit Member
Postby 2bits » Fri Nov 23, 2018 10:47 pm
Here are the before and after pics of the interior.I did this quick in two days because I am going camping tomorrow!!!
Thomas
2bits
2bit Member
Postby M C Toyer » Sat Nov 24, 2018 1:12 am
Great deal. Plain caps are cheap but the tool box sides and full height doors are extremely valuable and useful for your purposes.
Given your planned use you would almost have to call this a work truck with sleeping accommodations. Did you at one time mention doing mobile repairs as well as your home based rebuilds?
I traveled all over Texas for many years in a Jeep PU with just a tarp for cover and some homemade wooden boxes on the sides pulling a 16' tandem trailer with all my carpentry tools and construction material. Spent many a night in roadside parks or on jobsites usually on a cot in the PU bed.
M C Toyer
Images: 11
Postby Hardryder56 » Tue Dec 18, 2018 8:59 pm
Very nice score on that topper. It turned out looking pretty good inside
Coffee is like liquid hugs, it warms you from the inside out
Hardryder56
Postby 2bits » Tue Dec 18, 2018 9:28 pm
Thanks! I have since added an RV 110 inlet and two outlets inside, built some shelves inside for a more finished out look and traded in the foam mattress for a real twin mattress after the first outing. Looking much better, and got my campsite setup all figured out too.
Thomas
2bits
2bit Member
Postby aggie79 » Wed Dec 19, 2018 8:57 am
Sweet! :thumbsup: :applause: :thumbsup:
Postby featherliteCT1 » Wed Dec 19, 2018 3:27 pm
I like it!
featherliteCT1
