How do i get this hose onto this fitting?
Postby atcNick » Mon Jan 07, 2019 4:40 pm
Both hose and fitting are 1 1/4”. It’s the fitting and hose I bought for filling my water tank in the cargo trailer. I can’t get this hose onto the fitting, any suggestions? Tricks?
-Nick
atcNick
Re: How do i get this hose onto this fitting?
Postby rainjer » Mon Jan 07, 2019 4:58 pm
Put the end of the hose in boiling water to soften up a little.
Jeremy
rainjer
King Koleman
Images: 11
Postby atcNick » Mon Jan 07, 2019 5:18 pm
rainjer wrote:Put the end of the hose in boiling water to soften up a little.
Jeremy
Great idea! Thank you
-Nick
atcNick
Postby atcNick » Mon Jan 07, 2019 5:48 pm
Jeremy
2 second dip caused this! Looks like the blue/green part can’t handle the heat
-Nick
atcNick
Postby GTS225 » Mon Jan 07, 2019 6:10 pm
Hmmmm. We know it can't handle as little as 212*F. You might try a little Vaseline on the inside of the hose, then apply judicious force and attempt to screw the fitting into the hose.
Roger
GTS225
Postby atcNick » Mon Jan 07, 2019 7:26 pm
GTS225 wrote:Hmmmm. We know it can't handle as little as 212*F. You might try a little Vaseline on the inside of the hose, then apply judicious force and attempt to screw the fitting into the hose.
Roger
I’ll give it a shot
-Nick
atcNick
Postby S. Heisley » Mon Jan 07, 2019 8:12 pm
Use hot water but not boiling hot. Test it with the parts that are already damaged to see that they don't melt at the temperature you're trying.
Postby pchast » Mon Jan 07, 2019 8:58 pm
did you try to gently warm it with a hair dryer or
heat gun on low/warm.....
pchast
Images: 97
Postby S. Heisley » Tue Jan 08, 2019 7:27 pm
pchast wrote:did you try to gently warm it with a hair dryer or
Yes, a hair dryer can work too. But, again, don't get it too hot.
Postby Shadow Catcher » Tue Jan 08, 2019 7:33 pm
I will go along with Sharon, I use hot water from the sink. You can also reduce the size of the fitting with a bit of judicious sanding.
Postby crttaz » Wed Jan 09, 2019 1:32 am
Only shove it on 1/2 way and clamp it.
Looks like a dual size fitting, 1.25" and 1.5"
crttaz
Postby Nodrog » Thu Jan 10, 2019 4:18 am
Hi- I believe I had the same thing...I cut off the small part then filed and sanded down the large part til I could put it on with a little soapy water. The barbs were gone. But it's a no pressure situation and tested, no leak. It got kinda thin, but I think not -too- thin. Shouldn't be too much stress on it cause the hose is real flexible. I think I used a little shaving soap from a can on it, it's really slick. Good luck! Nodrog
Nodrog
