GPW wrote:What’s a Class A finish ??? Like your car … ?
GPW wrote:SF, we discussed this a long time ago , and it was mentioned this was the most difficult , laborious , and time consuming finish you can put on foam ( compared to normal foam covering PMF and a weave finish ) … But I guess you read about that already eh ?
There are a lot of boats out there that a "foam" covered with epoxy and fiberglass.
tony.latham wrote:There are a lot of boats out there that a "foam" covered with epoxy and fiberglass.
He's using polyester resin. That's the issue.
theoldwizard1 wrote:tony.latham wrote:There are a lot of boats out there that a "foam" covered with epoxy and fiberglass.
The first video they are clearly using epoxy https://youtu.be/OyKy-cDy6e8?t=176
Same with #2 https://youtu.be/MY4Czpc8AXY?t=360
Users browsing this forum: Google [Bot] and 0 guests
