StrongFeather wrote:Yep! Just another example of me not being good at 'splainin' - and trying a little too hard to be brief. The windows will be commercial units with screens. One in each door and one larger one across the top of the rear (above the rear-access storage area). The wood frames that I mentioned (briefly) will be made to fit the windows and then they'll get epoxied into the panel in place of the XPS foam board. The panel skin will then get routed out with a flush-cutting bit so that the windows will drop right in.
Atomic77 wrote:What are you going to do about the seams between the panels?
Looking good so far, keep up the good work
Atomic77 wrote:I would have run Enka mat down the center and "T'd" off a couple times with multiple inlets for a part that size. Would have cut the infusion time in half or more. Tapatalk
If one were sensitive to disappointment, this would be tough. But... you now know more than you did before, therefore mark another success. The panel looks great. Next time spray PVA (Polyvinylacetate) in your mold first. Simple and foolproof. Your part will practically fall out on it's own and the thin green film washes off with soapy water making clean up a snap.StrongFeather wrote:I pulled the first full-size panel from the mold yesterday and...
...It is B-E-A-Utiful!
The picture doesn’t do it justice. The skin is nice and smooth, pattern is true and the corners/edges are square. I’m really happy, relieved and surprised at how nice it came out.
And this happened as I was demolding...
Another lesson learned. The entire top pane of glass on the mold shattered as I was removing the part. The cause was my shortsightedness when I failed to apply mold release to the mold frame, causing it to be glued to the glass. The part released nicely, but was locked in the corner and just a little pressure on the part and BOOM!
So now I’m going to build a new table (the old one was warped so I had to shim between the table and glass) and rebuild the frame on the pane that didn’t break. If this one breaks, and there’s a chance that it will, I’ll buy a nice thick piece.
Cheers!
