Coleman 228F lantern
Postby bdosborn » Wed Aug 21, 2019 8:22 pm
I just got a 228F big hat up and running. It has a nice yellow light and the reflector makes it perfect for sitting on a picnic table.
Images: 777
Re: Coleman 228F lantern
Postby Wolfgang92025 » Wed Aug 21, 2019 9:30 pm
:thumbsup: :applause: 8)
Wolfgang
Wolfgang92025
Images: 651
Postby Tomterrific » Thu Aug 22, 2019 9:18 pm
Man, that is a sweet lantern. I have a 228 from 1967 that was given to me to replace the lantern that was stolen. I must get this cool old "Big Hat" running again.
Do you know about Peerless mantles? Made in India and better quality than Coleman. Made the same as Coleman mantels used to be made. I've heard they still use thorium!
Tt
Tomterrific
Postby bdosborn » Fri Aug 23, 2019 6:47 am
I had to replace the burner assembly, pump, and cap seal to get mine back up and running. I stumbled on the Peerless mantels when I was looking to see what model number I needed. I think I tied the string to tight on the first batch as they fell of the burner. I kept the mantle string as loose as I could on the second batch and they're working like a champ. The replacement pump has the leather cup and doesn't work worth a crap, I need something a little more synthetic.
Images: 777
Postby Tomterrific » Fri Aug 23, 2019 9:34 am
Bruce, The leather pump washer should be better than the plastic one. Did you oil it with motor oil? I've got all my two stoves and 4 ( now three... ) lanterns pumping by soaking the old washer with regular oil. I don't remove it from the shaft, just squirt oil all over the leather. I've had problems with the check valve at the bottom of the pump.
Tt
Tomterrific
Postby bdosborn » Sun Aug 25, 2019 4:15 pm
Yeah, I oiled it. It only engages about every 10th pump. My Peak One lantern has a synthetic cup and it works flawlessly.
Images: 777
Postby Dave A » Sun Sep 01, 2019 12:46 pm
It sounds like you did not work the oil into the pump cup. All that needs to be done is after soaking is to flex the cup until it is flexible.
Dave A
Postby bdosborn » Mon Sep 02, 2019 1:07 pm
I've been watching YouTube, I just ordered some Neatsfoot oil and I'll try soaking it in that.
Images: 777
Postby Tomterrific » Tue Sep 03, 2019 3:07 pm
Hmmm! I wonder if you are having problems with the check valve at the bottom of the pump. Does the pump shaft push back up while you are pumping? Those check valves have been a problem for me. I used some penetrating oil on every check valve to clean and loosen it up. Just spray a little at the bottom of the tube where the check valve resides. The penetrating oil also helps get the leather soft but I follow up with common motor oil on the leather.
Tt
Tomterrific
Postby bdosborn » Tue Sep 03, 2019 8:21 pm
I don't think it's the check valve but I'll try the penetrating oil if the cup fix doesn't work.
Thanks,
P.S. Just got a 200A, I've always wanted one...
Images: 777
