I may sleep with the counter up for a safer feeling as needed too.
I think the misses might insist if she ever comes along and some times the camp sight can get rowdy so up goes the shutter!
Don previous page? Thanks.
beachguy005 wrote:Not sure how you're going to mount those brackets, but if you haven't considered it, you'll need to rout dados in the 2x so the brackets are recessed flush to the face of the 2x. Otherwise you won't be able to lower the table to the down position.
flboy wrote:Tommy... Why don't you round/angle either end (significantly) so if you wander in the dark, the edge will guide you into the slot instead of bruising your thigh. Also, you can gain an inch if you do something similar to what Hank mentioned.
In any case, what is driving the depth size? What is the widest thing you may set there? I'd think it would only need to be a dinner plate deep plus an inch or so? It is a long surface, so still a lot of area? At this point, maybe rounding edge and shaving off an inch or two from depth may solve the problems of space and movement without doing anything drastic to the hinge arrangement.
beachguy005 wrote:If that's what you're going to do you'll have two options. Cutting the dadoes all the way through the 2x so the vertical leg of the bracket mounts directly to the wall, or just deep enough to the thickness of the closed bracket. If you go with just the depth of the bracket, you'll need to add filler blocks to give you wood to mount the lower part of the vertical leg. Your 2x is 3.5 and the bracket is maybe 6". A 1" deep dado will need 1/2" spacer.
You need to make sure your router can cut deep enough. You also want cut about 1/4" at a time. Don't try plowing out the cut in one pass and make sure the cuts are square and plumb.
To get a straight cut you should attach a guide to the piece your cutting. Scraps of wood screwed in would work. Don't try free handing the cut. With a router you'll never cut a straight groove.
It sounds complicated but it's actually pretty easy. Set a guide for each slot. Use a router bit that's wide enough for the brackets so you'll only need one pass for width. Set a 1/4" depth and cut each slot. Add 1/4" and cut each slot....add and repeat until you have the depth you need.
It will be easier if you remove the table top and hinges from the 2x. Otherwise you'll need to be careful as you near top with the router running to not nick the plywood top.
