for the profile below using "industry-standard" techniques (i.e. vertical wooden ribs that define the profile, horizontal wooden ribs for stiffness, plywood skin on exterior / interior)? It looks like sealing could be a major issue
tony.latham wrote:How wide is your cabin? And how long is your hatch? I would make sure the hatch can be covered with a single (5'x5') sheet of Baltic birch assuming it isn't greater than 5' in width.
The cabin is something like 56" across...
saywhatthat wrote:As much trouble some have with hatch spring back .Why not build the hatch first then build the rest of the pod to fit
la trappe?
Tony, I like the idea of building the hatch in place. What kind of hurricane hinge did you use? And is that edge trim along the roof necessary?
tony.latham wrote: Edge trim? There is none.
gpr5027 wrote:tony.latham wrote: Edge trim? There is none.
Err, sorry - Edge gasket? Weatherstrip? Edge seal? I'm still learning the lingo here. Where your roof skin ends and where your hatch begins, you notched the edge of the roof and installed some type of gasket. It looks like it lives underneath of the hurricane hinge once everything is buttoned up. Is this necessary, or is it extra insurance against water ingress? How did you know where to locate it relative to the hinge?
Edit: Hatch detail coming along..
