The forward shelf/storage is complete and glued and screwed in place. A piano hinge was used for the three sections. The middle section will house all the wiring. The fuse box is in place. Once all the trim pieces are in place I can start running wires around and installing lights.
- DSCF0172.JPG (25.03 KiB) Viewed 2108 times
All the ribs are in place and the birch headliner is finished. I did the headliner in three sections, and glad I did. It was a challenge getting them in place and bent.
- DSCF0169.JPG (35.08 KiB) Viewed 2108 times
The top where the roof vent is located is a curved surface. I will have to build a flange to accept the curve for the roof vent to lay flat on. But that is an issue for down the road. You can see in the photo that the top of the rib is curved, and the underside is flat. I did this so that the interior vent trim will lay flat to the ceiling and not need compensation trim piece. You can see what I mean from the interior photo. The ceiling is curved, then runs flat in the area of the vent, then curves again moving forward.
Also, I decided not to build a cabinet in the area of the vent. Rather, I will use a cargo net for storage. I could always add some cabinets in the future, but for now, I want to keep the cabin as open as possible.
- DSCF0170.JPG (29.51 KiB) Viewed 2108 times
