chiefvintage wrote:Well that didn’t take long! Found a great deal on a ‘20 Sierra V8 so I jumped on it! Both
trailer and truck sit nice and level when hitched.
BigDave_185 wrote:That’s nice right there, What transmission is in it?
flboy wrote:Lokes great! I did a similar faux granite on my dinette. Turned out nice. Did you use natural sponges to do it?
Sent from my SM-N970U using Tapatalk
chiefvintage wrote:Well just in time for warm weather, i purchased a portable AC unit. Installing a louvered vent outlet for the exhaust duct. 10,000 btu's is probably overkill for a 7x17 CT but i figure if i leave it off when unoccupied it will cool down pretty quick on a hot day. It also has de-humidifier function for those cool damp days. I really didn't want to hack any frame studs to install a cheaper window unit, i'll leave that for my windows install at a later date. Also installed a Fantastic vent fan in place of the OEM roof vent, which got destroyed by falling storm debris!
https://www.amazon.com/gp/product/B07DQ ... UTF8&psc=1
https://www.amazon.com/gp/product/B07L9 ... UTF8&psc=1
flboy wrote:chiefvintage wrote:Well just in time for warm weather, i purchased a portable AC unit. Installing a louvered vent outlet for the exhaust duct. 10,000 btu's is probably overkill for a 7x17 CT but i figure if i leave it off when unoccupied it will cool down pretty quick on a hot day. It also has de-humidifier function for those cool damp days. I really didn't want to hack any frame studs to install a cheaper window unit, i'll leave that for my windows install at a later date. Also installed a Fantastic vent fan in place of the OEM roof vent, which got destroyed by falling storm debris!
I really hope that works better for you than the one I had in my first CTC did. The one hose type in particular do not typically work well at all for real hot weather in this application because they are pushing air outside and pulling air from the room. That being the case, they will constantly be pulling in air from outside. During the hot part of the day, they push out cold air, but never cool the room. The 2 hose type work better because they draw air from outside and discharge it at the same rate in a closed loop from outside. Plenty to read up on in these threads if you do a search. I hope your outcome is better... but just wanted to tell you so you are not surprised.
chiefvintage wrote: I do ride my motorcycle year round still, love the cold weather!
